29640 Discussions
SIZE on unallocated array does not trap with /check:pointer
Devorah_H_Intel
@tobias-loew could you please provide a test case of what exactly is not working with /check:pointer, also a compiler version used.
We tested internally and it seems to be working just fine, an error message is issued at runtime:
Size of the unallocated allocatable array:           0
forrtl: severe (408): fort: (8): Attempt to fetch from allocatable variable ALLOCARRAY when it is not allocated
tobias-loew
Hi @Devorah_H_Intel ,
when I run the following code, compiled with
/nologo /debug:full /Od /warn:all /module:"x64\Debug\\" /object:"x64\Debug\\" /traceback /check:all /libs:dll /threads /dbglibs /c
and linked with
/OUT:"x64\Debug\Console1.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"x64\Debug\Console1.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"C:\Users\**bleep**\source\repos\Console1\Console1\x64\Debug\Console1.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"C:\Users\**bleep**\source\repos\Console1\Console1\x64\Debug\Console1.lib"
on "Intel® Fortran Compiler 2025.1"
then it does not trap.
    program Console1
    implicit none
    integer, allocatable :: arr(:)
    integer :: size_of_array
    ! Intentionally call SIZE() on an unallocated array to trigger an error
    size_of_array = size(arr)
    end program Console1
I attached the project.
