29649 Discussions
Cannot export Fortran procedure pointer from DLL
johnyb_
I am trying to export a procedure pointer but it does not show up in the DLL's exported symbols
Code for the DLL:
module dll_proc_ptr
    abstract interface
        subroutine a_callme
        end subroutine
    end interface
    procedure(a_callme), pointer :: r_callme
!DEC$ ATTRIBUTES DLLEXPORT :: r_callme
    contains
    subroutine test_call
!DEC$ ATTRIBUTES DLLEXPORT :: test_call
        if(associated(r_callme)) then
            call r_callme
        else
            print *, "r_callme not associated"
        endif
    end subroutine
end module
Code for the calling program
program test_proc_ptr
	use dll_proc_ptr
	call test_call
	r_callme => my_callme
	call test_call
	contains
		subroutine my_callme
			print *, "this is my_callme"
		end subroutine
end program
If I omit the DLLEXPORT and link the module statically it works:
C:\TEMP\x>ifort dll_proc_ptr.f90 /c
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.110 Build 20150815
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
C:\TEMP\x>ifort test_proc_ptr.f90 dll_proc_ptr.obj
Microsoft (R) Incremental Linker Version 11.00.61030.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:test_proc_ptr.exe
-subsystem:console
test_proc_ptr.obj
dll_proc_ptr.obj
   Creating library test_proc_ptr.lib and object test_proc_ptr.exp
C:\TEMP\x>test_proc_ptr
 this is my_callme
C:\TEMP\x>
However when I compile the module as a DLL, the procedure pointer is not exported and the link of the test program fails of course:
C:\TEMP\x>ifort dll_proc_ptr.f90 /dll
-out:dll_proc_ptr.dll
-dll
-implib:dll_proc_ptr.lib
dll_proc_ptr.obj
   Creating library dll_proc_ptr.lib and object dll_proc_ptr.exp
C:\TEMP\x>dumpbin -exports dll_proc_ptr.dll
Microsoft (R) COFF/PE Dumper Version 11.00.61030.0
Dump of file dll_proc_ptr.dll
File Type: DLL
  Section contains the following exports for dll_proc_ptr.dll
    00000000 characteristics
    564D8BDC time date stamp Thu Nov 19 09:44:12 2015
        0.00 version
           1 ordinal base
           1 number of functions
           1 number of names
    ordinal hint RVA      name
          1    0 00001010 DLL_PROC_PTR_mp_TEST_CALL
  Summary
        1000 .data
        1000 .pdata
        1000 .rdata
        1000 .reloc
        1000 .text
C:\TEMP\x>
I don't see in the documentation of the DLLEXPORT attribute that it excludes procedure pointers.
Johny
mecej4
You posted the same code twice. Please correct the second code (for the main program).
johnyb_
Oops, I'm sorry.
I have updated my post.
Thanks for bringing this to our attention - we'll take a look. Issue ID is DPD200378960.
I expect this to be fixed in Update 2 (February).
