I have experienced many times a wrong trace back listing in case of run time errors.
The following is a case:
Output/plot unit 7 PL1 - time 4:00:00 P. 49
forrtl: error (73): floating divide by zero
Image PC Routine Line Source
XDSIMV10.EXE 00F32D62 _HB256 272 V1CORR56.FOR
XDSIMV10.EXE 010783B1 _DY56_FLOW 1071 V0DUOP56.FOR
XDSIMV10.EXE 01077EF5 _DY56_FLOW 1135 V0DUOP56.FOR
XDSIMV10.EXE 0107273C _DYUO56 263 V0DUOP56.FOR
XDSIMV10.EXE 00F8DC06 _DY02_PROP 156 v0prop02.for
XDSIMV10.EXE 00F880CC _DY02_PROP 193 v0prop02.for
XDSIMV10.EXE 0101CD2D _DYNAMIC_SOLUTION 1044 V0DYNSOL.FOR
XDSIMV10.EXE 01130866 _MAIN__ 525 V0XDSIM.FOR
XDSIMV10.EXE 013FACA2 Unknown Unknown Unknown
XDSIMV10.EXE 011D6172 Unknown Unknown Unknown
kernel32.dll 7649EE6C Unknown Unknown Unknown
ntdll.dll 76E03AB3 Unknown Unknown Unknown
ntdll.dll 76E03A86 Unknown Unknown Unknown
The subroutine DYUO56 is not called by DY02_PROP and the double listing of DY02_PROP is also wrong.
The routine called at line 1044 of V0DYNSOL.for is not DY02_PROP. The initial lines of the trace-back are correct so the error point can be identified. However these imperfections do not place the user at easy.
COMPILER: Intel(R) Visual Fortran 15.0-1750
Without seeing a test case, I would guess that there is procedure inlining happening, which will cause traceback to be perhaps more confusing. Are you able to provide us a test case we can build and run to check it out?
Steve,
it will take too much effort and time to prepare a test case from thousands of lines of codes.
The DY02_PROP routine was involved in a previous calling sequence.
What I can provide is an Excel form showing the two calling sequences; i.e. the one generating the error (xyz56_... path) and the previous one (xyz02_... path).
Yes, but that is necessary in order to move forward towards a solution. First, we have to establish that there exists a bug. It is only after doing so that we can look for a solution.
Suppose you have a program with a few thousand lines of code, which reads some data and produces results. You provide the EXE to a colleague, who runs the program and uses the output. Most of the time, the colleague finds the results "fine". For some inputs, however, she finds the results "suspect". Would you undertake to debug your program without being given at least one set of input data for which the results are suspect?
Now instantiate the program with a suspected bug as the compiler (behind it may be millions, rather than thousands, of lines of code). Luigi's programs are the input data to the compiler. The compiler is the EXE of the preceding paragraph, and Luigi is the "colleague". Most of the time, the compiler produces fast, correct output (working EXEs). The colleague (Luigi now) has found one input data set (thousands of lines of source code that may have caused the compiler bug to occur). Unless he provides the data (the source code of his malfunctioning program) to the compiler developer team, what can they do to solve the problem?
Following Steve's suggestion, you could try suppressing inlining or setting debug:inline-debug-info to attempt a more accurate traceback.
To complete the discussion about this subject.
The trace back seems to loose the calling sequence and mix the last sequence which generates the error with the previous one. The two sequences are as follows:
Main is : PROGRAM XDYNSIM but the name is lost.
Call sequence 1 (completed with no errors) :
_MAIN__ at line 525 of V0XDSIM.FOR calls
_DYNAMIC_SOLUTION at line 1044 of V0DYNSOL.FOR calls
_UOPXX at line 796 of v0uopxx.for calls
_DYUO02 at line 413 of v0duop02.for calls
dy02_prop v0prop02.for
Call sequence 2 :
_LNK_UOP at line 411 of V0lnksol.for calls
_LNK_SOL at line 978 of V0LNKSOL.for calls
_uopxx at line 362 of v0uopxx.for calls
DYUO56 at line 263 of v0duop56.for calls
dy56_flow at line 1468 of v0duop56.for calls
dy56_fric line 1468 of v0duop56.for calls
_HB256 in module V1CORR56.FOR
The subroutine DY56_FRIC is inlined in the release version.
Compiler developers should give a look into this.
Sorry, without a test case there's nothing to look at.
