29652 Discussions
Cannot watch automatic arrays in debug mode
Jon_D
New Contributor II
In the following code, in debug mode, I am not able to see the values stored in the three automatic arrays in the DoSomething subroutine. Watch window shows them as arrays with dimension of 15, but the values show as "Undefined address". This happens with IFX; IFORT is fine. Is there a way to circumvent this issue?
I am using VS 2022, oneAPI 2024.2.1.1083
module aModule
    implicit none
contains
    subroutine DoSomething(ne,ilutype)
        integer,intent(in) :: ne,ilutype
        real(8),dimension(ne) :: relemvalues,relemvalues_short,relemvalues_surplus
        select case (ilutype)
            case (1)
                relemvalues = 5.0
            case (2)
                relemvalues = 8.0
            case default
                relemvalues = 1.0
        end select
        relemvalues_short   = 0.0
        relemvalues_surplus = 0.0
    end subroutine DoSomething
end module aModule
program main
    use aModule
    implicit none
    integer :: ne,ilutype
    ne      = 15
    ilutype = 1
    call DoSomething(ne,ilutype)
end program main
