Cantera
felipeabrao
Hello, everybody!
I do not understand much about computers, but would like to know something. I try to use a module called Cantera, but have the following error message after compiling the main program:
Error: This is not a DEC Fortran module file. [CANTERA]
use Cantera
Could anybody please help me? Thank you.
Sincerely,
Felipe
Module files are precompiled declarations. The .mod file (this is usually the file type) is compiler-specific - compiler A will not read a .mod file generated by compiler B.
My guess is that you are using Compaq Visual Fortran, or perhaps a very old version of Intel Visual Fortran. The Cantera software you got was built for use by some different compiler. You will need to get a version of Cantera built for use with your compiler, or switch compilers to one that is compatible.
Martin_Knirsch
Quoting - felipeabrao
Felipe,
a module is a program unit used to define global data in a single place. It contains data object declarations, derived types, procedure and procedure interface definitions etc. A program (unit) that accesses the module can make use of all module content.
Digital Fortran comes with a module wizard that generates F90 modules that makes it easy to call automation services from a fortran program; see "using com an automation objects" in the dec programmers guide.
I assume you link your application against a precompiled library compiled with another fortran compiler that is creating a different module interface. Try to get hold of the source of this module, include it into your code and recompile.
Good luck
Martin
Hello, everybody!
use Cantera
Sincerely,
Felipe
felipeabrao
Hello! I would like to thank you for your help! Yes, I use Visual Fortran 6.0, but I did not have the .mod file for Cantera. I friend of mine gave me hers. Before that, the errors were:
Could not find the file Cantera.mod.
and
Error: Error in opening the Library module file. [CANTERA]
use Cantera
Error executing df.exe.
I will try to follow your tips. Thank you again!
Felipe
