Capitalization of module names
slowder
I'm compiling some Fortran modules and their names are
getting capitalized. For example, my code is test_mod.F and it
defines the module test which comes out as TEST.mod.
Is there a flag in version 7.0 that turns off this
capitalization and keeps module names in lower case?
thanks,
Steve
Martyn_C_Intel
By convention, the names of the .mod files are upper case. I do not know of a way to change this. Since the Fortran language is not case sensitive, I'm not sure why you would want to do this, apart from aesthetics. If you have a need, please submit a request to Intel Premier Support at https://premier.intel.com
Symbol names in an object file are another matter, since these may be linked to objects built outside Intel Fortran. There are several ways to control the case and name decoration of symbol names.
Martyn
gmorris
> aesthetics.
For example, it makes it more difficult to write Makefiles if the module names get uppercased.
Point taken... :)
