Case select Warning
rahzan
I use a bunch of constants like SQL_F_TINYINT in a module
On a line of code which uses the module
case(SQL_F_TINYINT); sizeofCol=1
I get:
Warning: Case selection values must fit within a signed 32 bit integer. Value truncated.
Can anyone tell me what this means?
I sounds like an overflow, but how?
FYI the relevant values of the constants are
integer,parameter:: SQLSMALLINT_KIND=2
integer(SQLSMALLINT_KIND),parameter:: SQL_INTEGER = 4
integer(SQLSMALLINT_KIND),parameter::SQL_C_LONG =SQL_INTEGER
integer(SQLSMALLINT_KIND), parameter:: SQL_SIGNED_OFFSET = (-20)
integer(SQLSMALLINT_KIND),parameter::SQL_F_SLONG= (SQL_C_LONG+SQL_SIGNED_OFFSET)
Thanks in adv.
Tim
Jugoslav_Dujic
Valued Contributor II
FWIW, I occasionally get such messages when I accidentaly refer to an old (CVF 5.0D) .mod file within a new project. A rebuild takes care of it.
Jugoslav
This might be a compiler bug we recently fixed. If you'll provide a short but complete examplr, I'll check.
Steve
rahzan
This is the gist of the program, If I use the module as written out below, it does not produce the warning. I get
the warning if I use the module f90sqlconstants provided by Canaima which is compiled separately and used as an Object file. I do not know if I it is proper to attach the file from canaima w/o permission.
If you have the dang thing then we're cool.
Else, I will write Marco about it.
! module constants
! integer,parameter:: SQLSMALLINT_KIND=2
! integer(SQLSMALLINT_KIND),parameter:: SQL_INTEGER = 4
! integer(SQLSMALLINT_KIND),parameter::SQL_C_LONG =SQL_INTEGER
! integer(SQLSMALLINT_KIND), parameter:: SQL_SIGNED_OFFSET = (-20)
! integer(SQLSMALLINT_KIND),parameter::SQL_F_SLONG= (SQL_C_LONG+SQL_SIGNED_OFFSET)
! end module
use f90sqlconstants
integer(2) var
var=2
select case(var)
case(SQL_F_SLONG); write(*,*)'Jello mold'
case default
end select
end
Jugoslav_Dujic
Tim, if you open the file f90sqlconstants.mod in Visual Studio (as binary file), what are bits 25-28? All my modules built with CVF6.6 have 26 2E 36 00 = "6.6"C, and I guess this is the compiler version signature (old 5.0 header files have zeros). I'd guess Canaimasoft supplied some older .mod files; if you have the sources of F90SQL, I'd suggest you recompile them and put the new .mod files back into their directory. And, yes, tell Marco about the problem.
Jugoslav
The old module should not be a problem. We support that.
Steve
Jugoslav_Dujic
Not 100% I'm affraid. OK, here we go. I have only 5.0D and 6.6B to experiment with so I can't comment on other inter-versions, but if I compile low-level modules with 5.0D first:
MODULE XFTTYPES
INTEGER,PARAMETER::        XPROC_DIALOG      = -1
END MODULE
and then higher-level modules with 6.6B:
MODULE XFTWND
USE XFTTYPES
CONTAINS
RECURSIVE INTEGER FUNCTION PXDefProc)
   SELECT CASE (xWnd%lpWindowProc)
   CASE (XPROC_DIALOG)  !Dialog window
         PXDefProc = 0
I get:
D:...SourceXFTWnd.f90(1748) : Error: The case-value is out-of-range.
that happens for negative PARAMETERs only. It's not identical as Tim's case, but looks suspiciously similar.
Jugoslav
Jugoslav_Dujic
...and I'm certain I saw the same warning as Tim under similar circumstances, but at the moment I can't recall what they were exactly.
rahzan
Ok I tried including the source and force recompiling it and the warning want away.
Jugo's msg did not say bit 25h or decimal so I could not verify his hint, for sure. if he meant hex then, yes, they were all zeros in the mod file.
Does this convince Steve?
tim
Jugoslav_Dujic
Yes, I meant 25h.
Jugoslav (who is 1E years old :-))
rahzan
Oh the hex of youth!
Ok, we'll take a look. It is SUPPOSED to work.
Steve
