Case sensitivity issue
Ibrahim_A_
I am running Intel fortran in Visual Studio. The code used to be case- insensitive, but it accidently changed to be case-sensitive now. I may have changed something in the settings. How can I turn it back to case-insensitive?
Steve_Lionel
There is a compiler option /names. If you changed it to /names:as_is, you'll see that behavior. Remove the option. (My usual advice is to never use /names - if you need to adjust for case-sensitive external names, use BIND(C,NAME=) or an interface block with !DEC$ ATTRIBUTES ALIAS.)
Steve_Lionel
Ibrahim_A_
How can I access the names option in visual studio? I have searched it but I couldn't find it.
Arjen_Markus
If you open the Properties for a project or a particular source file, select the tab External Procedures - the Name Case Interpretation option is the one you want. Set it to Default.
Ibrahim_A_
/names is set to default but the code throws an error if the case is not matching.
Arjen_Markus
Can it be that some part of the code has been compiled with /names set to some other value? Or are you calling C functions?
Steve_Lionel
In the project properties, go to Fortran > Command Line. Is anything showing under Additional Options? If so, remove it. Make sure you are looking at the current configuration that you are building.
If /names shows under All Options, you have it set somewhere in the project.
Ibrahim_A_
The value of /names is the default in the other parts of the.
Yes, I'm using interoperable C calls in this code.
Arjen_Markus
Then you should be aware that the names of C Functions are case-sensitive and the names of Fortran routines (in general) are not. As Steve suggested, use the BIND(C,name="...") attribute to bridge the naming confusion between C and Fortran.
Ibrahim_A_
Steve,
I had /fpe-all:0 in the additional options. When I removed it, the code is still case-sensitive.
@Arjen_Markus ,
I had the interoperable calls commented out to deactivate them, but the code is still case-sensitive.
Steve_Lionel
The /fpe-all is fine. Please attach a zip of 1) the source where the bad reference occurs, 2) the buildlog.htm from a rebuild of the project (in the debug or release folder, 3) the .vfproj file.
