29656 Discussions
Catastrophic error during compilation
richard_f_
when compiling my project I get the following error:
fcph.for(61): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for fcph.for (code 1)
this error happens after this command:
ifort -c fcph.for
I am using the following version of ifort
ifort (IFORT) 17.0.1 20161005
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
I am using
Red Hat Enterprise Linux Workstation release 7.3 (Maipo)
With
Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
The code compiles with no problem with the version 12 of ifort.
Any ideas? Thank you.
mecej4
This problem also occurs in the Windows 2017U1 compiler, and was previously reported. Please see https://software.intel.com/pt-br/node/702117 and https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/702945 . Perhaps the work-around suggested there will help you, too.
Kevin_D_Intel
Thank you for reporting the error Richard. Thank you mecej4 for the analysis and cross-reference to the earlier reports. I checked the earlier submitted internal tracking id and there is not a fix available yet.
(Internal tracking id: DPD200415852)
