Catastrophic error with Coarrays
velvia
Hi,The following program[fortran]program main implicit none integer, allocatable, codimension[:] :: x allocate(x
  • ) x = this_image() write (*,*) x deallocate(x
  • ) end program main[/fortran] which is not valid Fortran (the deallocate(x
  • ) should be deallocate(x)) makes the compiler crash.Best regards,Franois
  • 0 Kudos
    Anonymous66
    Valued Contributor I
    Hello Franois,
    Thank you for reporting this issue. I have escalated it to the developers. The issue number is DPD200233016. I will post any updates on the issue to this thread.
    Annnalee
    Intel Developer Support
    Anonymous66
    Hello Matt, A fix has been found for this issue. We are planning to include it in the next major release. Regards, Annalee Intel Developer Support
    Ron_Green
    This bug was fixed in the recent Composer XE 2013 SP1 release, released in early September ( version 14.0 of the compiler )
    ron
