29277 Discussions
Cautionary tail about lbound and ubound on 64-bit program
jimdempseyatthecove
Consider the following 64-bit program:
program foo
    implicit none
    real, allocatable :: array(:)
    integer(8) :: i
    i = Z'0000000100000000' + 5_8
    allocate(array(i)) ! 2^32 + 5
    print *,ubound(array), ubound(array,1,kind(i))
end program foo
 Output:
           5            4294967301
It is easy (for me) to overlook that the IVF language states:
The result type is integer. If kind is present, the kind parameter of the result is that specified by kind otherwise, the kind parameter of the result is that of default integer.
Therefore, in 64-bit programs care must be taken with arrays who's bounds exceed those of default integer (integer(4)).
This can introduce a programming error "Sight seen but unseen"
Jim Dempsey
Steve_Lionel
This applies to many intrinsics, and is exactly why the KIND argument was added to many of them.
I'll also comment that the assignment to i is non-standard, and the results implementation-dependent. Even in Fortran 202x, which expands the use of BOZ constants, this would not be allowed. See Doctor Fortran in "We're All BOZos on This Bus" - Doctor Fortran (stevelionel.com) for more information.
jimdempseyatthecove
I found that out
The compiler balked at:
    i = Z'0000000100000000' + 5 ! sans _8
FWIW would this be preferred?
   i = INT(Z'0000000100000000', kind(i)) + 5
Jim Dempsey
Steve_Lionel
That would be fine.
