Change DOS current directory
Nick2
If my STR is defined as 'CD "C:Program FilesBlah SomethingSomething" '
And I call,
CALL SYSTEM(STR)
Shouldn't this change my working directory? Doesn't seem to work :-
SYSTEM creates a new process. It changes the working directory of the new process, which then exits. Same thing if you try to do a "set" using SYSTEM. You want the SetCurrentDirectory Win32 API routine.
