29422 Discussions
Change in behavior of derived-type component initialization expressions
David_V_3
The following program compiles and runs with Intel Visual Fortran versions 10.1 through 14.0:
PROGRAM TESTTYPE
   TYPE MYTYPE
      INTEGER :: I => 0
   END TYPE MYTYPE
   TYPE(MYTYPE) :: X
   WRITE(*,*) X%I
END PROGRAM TESTTYPE
However, in versions 15 & 16 it fails with the following message:
testtype.f90(4): error #6680: A constant is not permitted in this context.   [0]
      INTEGER :: I => 0
compilation aborted for testtype.f90 (code 1)
It is noted that replacing the '=>' operator with '=' in the initialization expression works in all versions of the compiler tested.
QUESTION: What is the reason for the change in behaviour?
The IVF documentation states:
Is an initialization expression, or for pointer components, => NULL( ).
If init-ex is specified, a double colon must appear in the component definition. The equals assignment symbol (=) can only be specified for nonpointer components.
The initialization expression is evaluated in the scoping unit of the type definition.
One reading of the highlighted clause is that '=' or '=>' could be used for non-pointer components but that '=' must not be used for pointer components.
Many thanks,
David.
Kevin_D_Intel
I will research this changed behavior David and let you know what I find.
andrew_4619
Surely the compiler is just identifying bugs in your code that it did not identify before. The new behavior is an improvement!
IanH
For what it is worth, the text in the current standard makes it absolutely clear.
"If => appears in component-initialization, POINTER shall appear in the component-attr-spec list. If = appears in component-initialization, neither POINTER nor ALLOCATABLE shall appear in the component-attr-spec-list."
Kevin_D_Intel
Development believes parsing was also cleaned up for incorrect uses (as others noted regarding the Fortran Standard) of “=>” for non-pointer initialization in conjunction with this earlier post and internal tracking id DPD200157846 which was fixed in the 15.0 release, so this is the reason for the change in behavior.
I notified our Documentation writers about clarifying the init-ex component description and the statement you cited to make the "=" and "=>" uses clearer in a future revision.
(Internal tracking id: DPD200376067)
David_V_3
Thank you for looking into this issue Kevin and thank you Ian H for pointing out relevant text in the standard ... the latter may be of assistance to the Intel documentation writers in their review of the init-ex component description.
David.
Kevin_D_Intel
You're welcome David. Yes, I agree. I passed along IanH's earlier citation to the Doc writers. It was helpful and very clear.
FortranFan
Kevin,
Please see my Message #11 in another thread where documentation is being discussed:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/592538#comment-1839556
