intel compiler does not work
Alexander_T_1
I have installed the Intel compiler using two files
w_fc_c_10.0.027.exe and w_mkl_p_10.0.5.025.exe
on the ASUS notebook with OS Windows 8.1.
The process of installation has not any problem.
There are two new applications appear in the Start menu
"Fortran Build Environment for applications running on IA-32" and similar for IA-64
When I click on this button a black window with prompt command appears
I print "ifort c:\program.f90" (as usual I did on the old computer with the old compiler)
and compiler answers with the standard lines and
at the end a new line appear:  "LINK:  fatal error LINK1104: cannot open file "program.exe" "
I do not know how to compile and run the program inside the Visual Studio 8.
Also I do not know how to print correctly the command "tasklist | findstr / | program.exe"
after the line "ifort c:\program.f90" or as the new line?
Also I do not know how to reply on the comments. I want to discuss the problem with
some specialist in details. How to find the possible error and remove it.
The ideas that problem may be due to the fact that the windows is new and compiler is old
are interesting, but I can not investigate it using many computers with different windows
and different compilers. I want to know the answer on the simple question
Should the compiler  w_fc_c_10.0.027.exe work under the windows 8.1?
If not, I will search another way.
Kevin_D_Intel
