Changing variable type within in SELECT TYPE statement
Jacob_Williams
New Contributor III
I came across something interesting (see simple example below). Clearly, what I'm doing is wrong, but I was wondering if the compiler shouldn't complain more about it. I'm basically changing the type of a polymorphic variable within a select type construct. When I then try to access a variable that should no longer be there, it doesn't complain, but instead gives me the value of the variable in the new type.
module test_module
 implicit none
 type,abstract :: blah
 end type
 type,extends(blah) :: int_blah
  integer :: i = 999
 end type int_blah
 type,extends(blah) :: real_blah
  integer :: r = 888.0
 end type real_blah
 type :: segment
  class(blah),allocatable :: b
 contains
  procedure :: change_b
 end type segment
 contains
 subroutine change_b(me,i)
  !! change the type of me%b
  implicit none
  class(segment),intent(inout) :: me
  integer,intent(in) :: i
  if (allocated(me%b)) deallocate(me%b)
  select case(i)
  case(1)  !to int
   allocate(int_blah :: me%b)
  case(2)  !to real
   allocate(real_blah :: me%b)
  end select
 end subroutine change_b
end module test_module
program test
 use test_module
 implicit none
 type(segment) :: seg
 allocate(int_blah :: seg%b)
 select type (b => seg%b)
 class is (int_blah)
  write(*,*) 'b%i:',b%i
  !change to real:
  call seg%change_b(2)
  !b is now real_blah
  !but, this prints 888.0...
 end select
 !just to make sure it worked:
 class is (int_blah)
  write(*,*) 'b is int:',b%i
 class is (real_blah)
  write(*,*) 'b is real:',b%r
 end select
end program test
The output is:
 b%i:         999
 b%i:         888
 b is real:         888
Arjen_Markus
I am not sure that the compiler can detect this change. It is akin to:
real, dimension(:), pointer :: p
real, dimension(:), allocatable, target :: array
allocate( array(10) )
p => array
deallocate( array )
write(*,*) p
Such dangling pointers are difficult if not impossible to detect completely reliably (like the classic halting problem).
Most probably the fact that the data structure is so small makes the program print the old value. But that is just a "lucky" coincidence.
Steven_L_Intel1
I agree with Arjen.
