29276 Discussions
Character concatenation operator with character variables
john35802
I have CVF 6.6 Professional 6.6A. Why doesn't the character concatenation operator work with character variables. For example, consider the following code:
TEXT1 = ADJUSTL( TEXT1 )
TEXT1 = TRIM( TEXT1 )
TEXT2 = ADJUSTL( TEXT2 )
TEXT2 = TRIM( TEXT2 )
TEXT = TEXT1 // ' ' // TEXT2
Where all three variables were declared as character (256), and text1 and text2 were previously assigned values, then by what I have read in the language reference manual, the final result assigned to TEXT should contain what's in TEXT1, followed by a blank character, followed by what's in TEXT2. However, what actually happens is that TEXT is assigned what's in TEXT1 only. The complier also warns me that this line won't work. Is this behavior in accordance with Fortran 95, or is this a defect of CVF?
wkramer
You should use:
TEXT=TRIM(ADJUSTL(TEXT1))//''//TRIM(ADJUSTL(TEXT2))
The statement:
still leaves you with a 256 character string.
Appending a string to the end doesn't contribute to the result because TEXT also has 256 characters
Walter
john35802
Thankyou. That was it.
