Circular dependency dropped
milenko1976
Again I have this problem.Trying to compile one program,changed it slightly but I get this:
make: Circular findiff2d <- findiff2d.o dependency dropped.
findiff2d calls 9 subroutines some of them are called from main program too.Is that problem?
This is my makefile:
77 = ifort
LD = ifort
CPPFLAGS = -C -traditional $(DFLAGS) -I$(INTEL_INC)
FCFLAGS = $(DFLAGS) -I$(INTEL_INC) -fpp -g
LDFLAGS = $(FCFLAGS)
LIBS = -L$(INTEL_LIB) -lmkl_intel_lp64
OBJECTS_ARCHITECTURE = machine_intel.o
# Executables
main: main.o model.o time.o findiff2d.o misc.o blkdat.o fd.par fd.com
$(F77) $(FLAGS) -o main main.o model.o time.o findiff2d.o misc.o blkdat.o
# Object files
main.o: main.f fd.par fd.com
$(F77) $(FLAGS) -c main.f -o main.o
model.o: model.f fd.par fd.com
$(F77) $(FLAGS) -c model.f -o model.o
time.o: time.f fd.par fd.com
$(F77) $(FLAGS) -c time.f -o time.o
findiff2d.o: findiff2d fd.par fd.com
$(F77) $(FLAGS) -c findiff2d.f -o findiff2d.o
misc.o: misc.f fd.par fd.com
$(F77) $(FLAGS) -c misc.f -o misc.o
blkdat.o: blkdat.f fd.par fd.com
$(F77) $(FLAGS) -c blkdat.f -o blkdat.o
TimP
You appear to have introduced so many typos we can't judge accurately about your question.
Might the correct version involve
findiff2d.o: findiff2d.f ...... ?
Apparently, what you put there implies findiff2d.o depends on itself, a seemingly likely interpretation.
It doesn't make sense to introduce -lmkl_intel_lp64 by itself, but you don't show how you might use it.
milenko1976
Thanks Tim.
Regarding -lmkl_intel_lp64,I copied makefile from my another program.Changing findiff2d.o: findiff2d.f doesn't solve the problem.
mecej4
The make utility does not concern itself with the contents of the source files it is about to hand over to compilers to process.
There is a built in make rule that says that linking xxxxx.o produces the executable xxxxx, in the absence of other information provided in the makefile for building xxxxx.
Since, because of you mistake in leaving out ".f" after findiff2d, as Tim18 pointed out already, findiff2d is declared a prerequisite to findiff2d.o, and make tries to figure out how to build it.
Since there is no explicit rule given to make this prerequisite, findiff2d, make uses the built-in rule, which in effect makes the following rules apply:
findiff2d.o: findiff2d # explicit rule
findiff2d: findiff2d.o # built-in rule
The circular dependency is now clearly seen.
The fix, as Tim18 stated, is to replace the erroneous line
by
findiff2d.o: findiff2d.f fd.par fd.com
To see how make applies built in rules, try the command
make misc
milenko1976
Thanks Mecej,now I see what is wrong.
