Cluster OpenMP - more information?
tobias-burnus
on the compiler product pages of icc 9.1 and ifort 9.1 I found that they now support to use (slightly modified?) OpenMP directives to compile/run a program on a distributed-memory computer cluster.
Which is termed "Cluster OpenMP".
Unfortunally, the web is rather oblique on the details.
One finds a whitepaper:
http://cache-www.intel.com/cd/00/00/28/58/285865_285865.pdf
A conference of a high-performance computation center:
http://www.hlrs.de/news-events/events/2006/openmpworkshop/
And FAQ:
http://www.intel.com/support/performancetools/sb/cs-022403.htm
But no details.
On the ifort 9.1/Linux pages one finds:
"Cluster OpenMP enables a slightly modified OpenMP program to run on a Linux 64-bit Intel-based cluster."
What I really miss is:
(a) What are the modification needed?
(b) What are the pre-requirements/setups needed to use Cluster OpenMP?
Tobias
This whitepaper describes Cluster OpenMP in general. I've attached the User Manual to this reply.
I know that the system requirements include an Intel EM64T-based system, but I can't put my hands on the other system requirements right now. When I find them I'll let you know.
John_O_Intel
In addition to Intel EM64T processor, Cluster OpenMP supports Intel Itanium 2 processors. Attached are the Cluster OpenMP release notes - same for both C++ and Fortran. The release notes explain the supported Linux distributions, cluster requirements, etc.
Let us know if you have additional questions, thanks,
_|ohnO
