Does the standard allow a coarray to be a UDT type with allocatable components? From note 5.6 in the 2008 standard, the answer appears to be "yes":
A coarray is permitted to be of a derived type with pointer or allocatable components. The target of such
a pointer component is always on the same image as the pointer.
The same note appears in the 2018 standard, as note 1 in section 8.5.6.
OK, so if the component in question is a pointer component, it points to a target in the same image as the pointer. But what about when its an allocatable component? And, crucially for my work, what happens when the coarray is referenced from a different image?
In my work I am trying to copy coarray elements between images. I find that, if the UDT does not contain allocatable components, the copy works correctly, but not when it does.
If necessary I can knock up an example to show what I mean. But I don't want to do that if my understanding of the standard is incorrect.
I am using IVF 17.0.2.187 and 19.1.0.166.
Colin W. wrote:.. In my work I am trying to copy coarray elements between images. I find that, if the UDT does not contain allocatable components, the copy works correctly, but not when it does. ..
I am using IVF .. 19.1.0.166.
Submit a support request with Intel Online Service Center (OSC) if you're able to: https://supporttickets.intel.com/servicecenter?lang=en-US
My understanding is what you're doing is alright by the standard, especially with a component with the ALLOCATABLE attribute in a derived type and with copying data from another image in a coarray object of such a derived type. The issue(s) you face is likely more due to an implementation matter. Intel support can then hopefully guide you best.
This is more an illustration of a quick check and for any other readers wanting to try out coarrays in Fortran with a derived type that has an ALLOCATABLE component:
type :: t
integer, allocatable :: n
end type
character(len=*), parameter :: fmtg = "(g0,t15,g0)"
type(t), save :: fooC:\Temp>ifort /standard-semantics /warn:all /stand:f18 /Qcoarray:shared /Qcoarray-num-images=8 p.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121 Copyright (C) 1985-2019 Intel Corporation. All rights reserved. Microsoft (R) Incremental Linker Version 14.24.28316.0 Copyright (C) Microsoft Corporation. All rights reserved. -out:p.exe -subsystem:console p.obj C:\Temp>p.exe Image # foo%n 1 42 2 43 3 44 4 45 5 46 6 47 7 48 8 49 C:\Temp>
program test
type :: t
real(8) :: x1, x2, x3
real(8), allocatable :: xn(:)
integer :: i1, i2, i3
integer, allocatable :: in(:)
end type
With IVF 17.0.2.187 and for_coarray_num_images=2, the run either crashes, or gives the wrong answer for the allocatables:
C:\prog\test\co\x64\Debug>co
image 2 20.0000000000000 20.0000000000000
image 1 20.0000000000000 20.0000000000000
30.0000000000000 40.0000000000000 41.0000000000000
42.0000000000000 43.0000000000000 44.0000000000000
11 21 31 51 52 53
54
30.0000000000000 40.0000000000000 0.000000000000000E+000
0.000000000000000E+000 0.000000000000000E+000 0.000000000000000E+000
11 21 31 0 0 0
0
forrtl: severe (157): Program Exception - access violation
In coarray image 2
Image PC Routine Line Source
VCRUNTIME140D.dll 000007FEBB401330 Unknown Unknown Unknown
co.exe 000000013FF61F2C MAIN__ 26 eg.f90
co.exe 000000013FF62A2E Unknown Unknown Unknown
co.exe 000000013FF64404 Unknown Unknown Unknown
co.exe 000000013FF64317 Unknown Unknown Unknown
co.exe 000000013FF641DE Unknown Unknown Unknown
co.exe 000000013FF64419 Unknown Unknown Unknown
kernel32.dll 000000007718556D Unknown Unknown Unknown
ntdll.dll 00000000773E372D Unknown Unknown Unknown
application called MPI_Abort(comm=0x84000002, 0) - process 1
11 21 31 51 52 53
54
30.0000000000000 40.0000000000000 3.250556697118729E-318
11 21 31 0 0 0
0
In coarray image 2
co.exe 000000013F2D1F2C MAIN__ 26 eg.f90
co.exe 000000013F2D2A2E Unknown Unknown Unknown
co.exe 000000013F2D4404 Unknown Unknown Unknown
co.exe 000000013F2D4317 Unknown Unknown Unknown
co.exe 000000013F2D41DE Unknown Unknown Unknown
co.exe 000000013F2D4419 Unknown Unknown Unknown
In coarray image 2
VCRUNTIME140D.dll 000007FEBB791330 Unknown Unknown Unknown
co.exe 000000013FED1F2C MAIN__ 26 eg.f90
co.exe 000000013FED2A2E Unknown Unknown Unknown
co.exe 000000013FED4404 Unknown Unknown Unknown
co.exe 000000013FED4317 Unknown Unknown Unknown
co.exe 000000013FED41DE Unknown Unknown Unknown
co.exe 000000013FED4419 Unknown Unknown Unknown
11 21 31 0 0 0
0
11 21 31 51 52 53
54
With 19.1.0.166 I get an ICE:
1>------ Rebuild All started: Project: co, Configuration: Debug x64 ------ 1>Deleting intermediate files and output files for project 'co', configuration 'Debug|x64'. 1>Compiling with Intel(R) Visual Fortran Compiler 19.1.0.166 [Intel(R) 64]... 1>eg.f90 1>04010002_1529 1>C:\prog\test\co\eg.f90(26): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. 1>compilation aborted for C:\prog\test\co\eg.f90 (code 1) 1> 1>Build log written to "file://C:\prog\test\co\x64\Debug\BuildLog.htm" 1>co - 1 error(s), 0 warning(s) ========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Well, that's a shame on the compiler. Component-by-component assignments work: Intel Fortran compiler implementation appears to have issues with intrinsic assignment of derived types with ALLOCATABLE components in a coarray context and your support request here will hopefully get the Intel Fortran team to improve this aspect of their implementation.
type :: t
end type
character(len=*), parameter :: fmtg = "(g0,t15,g0,t35,*(g0,1x))"
type(t), save :: fooC:\Temp>ifort /standard-semantics /warn:all /stand:f18 /Qcoarray:shared /Qcoarray-num-images=8 p.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121 Copyright (C) 1985-2019 Intel Corporation. All rights reserved. Microsoft (R) Incremental Linker Version 14.24.28316.0 Copyright (C) Microsoft Corporation. All rights reserved. -out:p.exe -subsystem:console p.obj C:\Temp>p.exe Image # foo%x1 foo%in 1 20.00000000000000 51 52 53 54 2 20.00000000000000 51 52 53 54 3 20.00000000000000 51 52 53 54 4 20.00000000000000 51 52 53 54 5 20.00000000000000 51 52 53 54 6 20.00000000000000 51 52 53 54 7 20.00000000000000 51 52 53 54 8 20.00000000000000 51 52 53 54 C:\Temp>
But now, an ICE is always a compiler bug so Intel Fortran team should immediately accept that as a legitimate issue to work on.
Hopefully the couple of examples shown below can be reviewed by Intel Fortran team for consideration of cases toward their library of quality assurance (QA) and acceptance and validation checks of modern Fortran feature implementations such as coarrays and later toward their test suite for regression testing. That is, assuming such test libraries/suites are even present, at times one really has to wonder considering the defects that show up as to whether the vendor even bothers to do basic checks of their own with the implemented functionality or relies entirely on the users to discover the problems.
Example 1: defined assignment works with a simple derived type:
module m
type :: t
integer :: n = 0
contains
procedure, pass(lhs) :: assign_t
generic :: assignment(=) => assign_t
end type
contains
elemental subroutine assign_t( lhs, rhs )
class(t), intent(inout) :: lhs
type(t), intent(in) :: rhs
lhs%n = rhs%n
end subroutine
end module
use m, only : t
type(t), save :: fooExample 2: change the component in example 1 above to have an ALLOCATABLE attribute and the program does not work.
module m
type :: t
contains
end type
contains
lhs%n = rhs%n
end subroutine
end module
use m, only : t
type(t), save :: fooC:\Temp>ifort /standard-semantics /warn:all /stand:f18 /Qcoarray:shared /Qcoarray-num-images=8 p.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121 Copyright (C) 1985-2019 Intel Corporation. All rights reserved. Microsoft (R) Incremental Linker Version 14.24.28316.0 Copyright (C) Microsoft Corporation. All rights reserved. -out:p.exe -subsystem:console p.obj C:\Temp>p.exe forrtl: severe (157): Program Exception - access violation In coarray image 6 Image PC Routine Line Source p.exe 00007FF6BE801176 Unknown Unknown Unknown p.exe 00007FF6BE858E5E Unknown Unknown Unknown p.exe 00007FF6BE8591E0 Unknown Unknown Unknown KERNEL32.DLL 00007FFBBB8137E4 Unknown Unknown Unknown ntdll.dll 00007FFBBBE3CB81 Unknown Unknown Unknown forrtl: severe (157): Program Exception - access violation In coarray image 3 Image PC Routine Line Source p.exe 00007FF6BE801176 Unknown Unknown Unknown p.exe 00007FF6BE858E5E Unknown Unknown Unknown p.exe 00007FF6BE8591E0 Unknown Unknown Unknown KERNEL32.DLL 00007FFBBB8137E4 Unknown Unknown Unknown ntdll.dll 00007FFBBBE3CB81 Unknown Unknown Unknown forrtl: severe (157): Program Exception - access violation In coarray image 5 Image PC Routine Line Source p.exe 00007FF6BE801176 Unknown Unknown Unknown p.exe 00007FF6BE858E5E Unknown Unknown Unknown p.exe 00007FF6BE8591E0 Unknown Unknown Unknown KERNEL32.DLL 00007FFBBB8137E4 Unknown Unknown Unknown ntdll.dll 00007FFBBBE3CB81 Unknown Unknown Unknown forrtl: severe (157): Program Exception - access violation In coarray image 4 Image PC Routine Line Source p.exe 00007FF6BE801176 Unknown Unknown Unknown p.exe 00007FF6BE858E5E Unknown Unknown Unknown p.exe 00007FF6BE8591E0 Unknown Unknown Unknown KERNEL32.DLL 00007FFBBB8137E4 Unknown Unknown Unknown ntdll.dll 00007FFBBBE3CB81 Unknown Unknown Unknown forrtl: severe (157): Program Exception - access violation In coarray image 8 Image PC Routine Line Source p.exe 00007FF6BE801176 Unknown Unknown Unknown p.exe 00007FF6BE858E5E Unknown Unknown Unknown p.exe 00007FF6BE8591E0 Unknown Unknown Unknown KERNEL32.DLL 00007FFBBB8137E4 Unknown Unknown Unknown ntdll.dll 00007FFBBBE3CB81 Unknown Unknown Unknown forrtl: severe (157): Program Exception - access violation In coarray image 7 Image PC Routine Line Source p.exe 00007FF6BE801176 Unknown Unknown Unknown p.exe 00007FF6BE858E5E Unknown Unknown Unknown p.exe 00007FF6BE8591E0 Unknown Unknown Unknown KERNEL32.DLL 00007FFBBB8137E4 Unknown Unknown Unknown ntdll.dll 00007FFBBBE3CB81 Unknown Unknown Unknown forrtl: severe (157): Program Exception - access violation In coarray image 2 Image PC Routine Line Source p.exe 00007FF6BE801176 Unknown Unknown Unknown p.exe 00007FF6BE858E5E Unknown Unknown Unknown p.exe 00007FF6BE8591E0 Unknown Unknown Unknown KERNEL32.DLL 00007FFBBB8137E4 Unknown Unknown Unknown ntdll.dll 00007FFBBBE3CB81 Unknown Unknown Unknown C:\Temp>
