Coarrays: undefined reference to for_rtl_ICAF_LAUNCH
Jon_D
New Contributor II
I am trying to port a coarray fortran application from Windows to Linux (Ubuntu 16.04). This application compiles and works fine under Windows. I am using the Intel Fortran 19 Update 4. I applied all the compiler flags that were set on the Windows version including -coarray and -corray-num-images=10. Under Linux, when I try to compile, I get the following error:
Iwfm_f2.f90:(.text+0x76eb): undefined reference to `for_rtl_ICAF_LAUNCH'
An internet search turned nothing on this error. Can somebody let me know what I might be doing wrong?
Jon
Steve_Lionel
You get this when you try to link. Are you supplying the -coarray option on the ifort command that does the linking? The problem is missing a library (-licaf).
Jon_D
New Contributor II
Thanks, Steve. Providing the -coarray flag during linking solved the problem.
Jon
Steve_Lionel
On Windows, the compiler can put in object records that name libraries to search, but Linux doesn't have that feature, so you need to make sure that you supply the same compile options on the link step as some of them specify libraries to use.
