Coarrays with WinMain()
Chris_G_2
I have a problem with coarrays using Intel Parallel Studio XE 2011 on Windows 7. I have written some coarray code which works well as a standalone program with an impressive speed increase using 2/4 or 8 cores. I am now trying to integrate it into an existing Windows application using
 integer function WinMain(hInstance, hPrevInstance, lpszCmdLine, nCmdShow)
This is compiled with the coarray option enabled. However, when I interrogate the program for num_images() it always returns a value of zero and not 8 which is the number of cores on this computer. this_image() is always returned as 1.
The environmental variable NUMBER_OR_PROCESSORS returns a value of 8.
Help would be much appreciated!
Chris
Chris_G_2
I think I am being stupid (not for the first time): I need 2 seperate programs - the first compiled without the /Qcoarray option but using OpenMP, and the second, called from the first, compiled without OpenMP but using /Qcoarray:shared. Is this correct? Chris
Yes, if I understand what you're doing that's what you want. The second program with the coarrays should be something that could be run on its own as a console application.
