Code Coverage Features
Curran_K_
I am using code coverage on several tests and when I run the tool certain blocks are highlighted as uncovered but those blocks correspond to debugging. Is there a way I can program or manipulate the tool to ignore certain blocks/if statements instead of picking them up?
Thanks in advance
The techniques for doing this are described in the Code Coverage tool documentation. There are multiple options with granularity as fine as you want.
Curran_K_
I see, thank you for reminding me about the documentation.
Where exactly do I type those options about excluding code in, i.e -beginblkdsbl and -endblkdsbl?. Will it be in the source code?
Thanks Steve
Tools > Intel Compiler > Code Coverage... > Generate Report > Settings > codecov options > Additional options
Curran_K_
So does the exclusion of certain functions only occur if they are within a comment?
I don't quite understand your question. There are multiple ways of excluding portions of code. You can bracket sections with "begin and end" comments, you can add a comment on a particular line, you can exclude whole source files. A function cannot be "within a comment". I don' profess to be an expert in the code coverage tool, but I thought the documentation's examples were clear. Perhaps you could show an example of what you'd like to do if you're still uncertain.
