Code Coverage Generation
David_B_24
I have a large live Fortran solution which I periodically build with Code Coverage switched on by setting /Qcov-gen in a special copy of ifort.cfg file used for the purpose.
I want to disable some of the projects from the Code Coverage statistics and so I tried the documented option /Qcov-gen- in the Fortran project command line properties. Unfortunately this generated the following message for each source file:
ifort: command line warning #10006: ignoring unknown option '/Qcov-gen-'
How can I disable individual projects in my solution from being included in the Code Coverage report?
Isn't that interesting...  I will bring that to the developers' attention.
... and our crack tag-team of developers fixed the problem in our sources. The fix should appear in a compiler update later this year (October-ish).
