Is it possible to do code coverage analysis when using the new ifx compiler? There's a guide [1] for generating code coverage data, but the compiler arguments seems to only be supported by the old ifort compiler.
[1] https://www.intel.com/content/www/us/en/docs/fortran-compiler/developer-guide-reference/2023-0/code-coverage-tool.html
- « Previous
- 1
- 2
- Next »
'Idiots guide' attached. A working demo solution also attached.
Cheers,
Fran
I applied your solution, but I guess my version of ifx is too old - it accepts the option and the library, but my program did not produce any relevant output files. What compiler version do you use?
The latest version from 2026, but I know it worked with some previous versions.
Right, I am using 2025.3.2 at the moment. We will migrate to 2026 in a few weeks.
Topic Options
- « Previous
- 1
- 2
- Next »
