Code coverage using ifx
Paul_Levold
Is it possible to do code coverage analysis when using the new ifx compiler? There's a guide [1] for generating code coverage data, but the compiler arguments seems to only be supported by the old ifort compiler.
[1] https://www.intel.com/content/www/us/en/docs/fortran-compiler/developer-guide-reference/2023-0/code-coverage-tool.html
Barbara_P_Intel
I checked with the compiler team. Code coverage is not available with ifx.
Fran-Martinez
Is there any indication when the compiler team will implement this feture in IFX?
Since IFORT is no longer available, it is a problem to properly implement detailed unit tests.
Shiquan_Su
Hi, Fran:
We try to survey our customer community about different feature requests. If possible, would you please let us know your company/institute name, and the name of the app you plan to apply the code coverage functionality to? Is there a public website for your target app? Thanks,
Shiquan
Fran-Martinez
Hi, Shiquan,
I am more of a private user. I used to work in a company where Fortran was a key lnguage for space system applicaiton development and I am certain that they suffer the same issue with the code coverage using IFX.
There are some libraries in Github (https://github.com/ffadrique) that include all unit tests that I have always used to analyse the code coverage. I have another couple of libraries in the pipeline that I will only publish when I can complete the unit testing.
Cheers,
Fran
Devorah_H_Intel
This feature is planned for ifx 2026.
Mark_Lewy
Valued Contributor I
Interesting - LLVM compilers provide source code coverage capability from the command line.  Are you saying that ifx is not able to use this yet, or is the aim to provide reporting similar to ifort in OneAPI 2026?
Devorah_H_Intel
ifx is not able to use it, and the aim is to provide a code coverage feature similar to ifort.
Mark_Lewy
Thanks for the clarification @Devorah_H_Intel
For the OP, @Paul_Levold , a couple of suggestions:
If you still have OneAPI 2025.0 (or earlier) installed, you could still use IFORT and its code coverage tool.
Alternatively, you could try using GNU Fortran and the gcov tool to provide code coverage.
It's a good idea to get your code building with alternative compilers anyway, because they can pick up bugs in your code that the other compiler doesn't.
Fran-Martinez
indeed, I use gfortran with gcov for the unit test coverage, but this forces me to maintain two environments, which is a bit of an unnecessary burden. Still useful for portability and debugging.
JohnNichols
Honored Contributor I
When code coverage or speed is "Can we do an entire cycle in 8.192 seconds, 16834 divided by 2000 steps per second?" if yes, then it does not matter, if not change the FFT engine first.
Some people have simple lives.
And then the data tells you what happens when a large truck hits a larger bridge.  The bridge moves.  No idea about the truck.
Jacob_Williams
New Contributor III
did ifx coverage support make it into the 2026 release?
Mark_Lewy
Doesn't look like it, according to the release notes: Intel® Fortran Compiler for oneAPI Release Notes 2026.  Though I would treat them with a pinch of salt; the MKL release notes originally omitted the removal of some deprecated procedures.
Igor_V_Intel
Unfortunately, it is not available in 2026 version.
Fran-Martinez
What is the roadmap for this functionality to be available?
Jacob_Williams
New Contributor III
@Devorah_H_Intel Any updates on this?
Mark_Lewy
On Linux (I'm using Ubuntu 22.04 LTS on WSL), you can get ifx/icx to generate coverage information using --coverage.
The coverage data must be read with `llvm-cov gcov`, not the system `gcov`. lcov needs a *single-file* gcov tool, and `llvm-cov` requires its `gcov` subcommand — so passing `"llvm-cov gcov"` directly to `lcov --gcov-tool` fails with `geninfo: ERROR: need tool …!`. I created  a wrapper `llvm-cov-gcov` which forwards to `llvm-cov gcov`.  Pass an **absolute** path to `--gcov-tool` — geninfo `chdir`s into each object directory before running the tool, so a relative `./llvm-cov-gcov` resolves during the version probe but fails (`Can't exec`) once file processing begins.
Once you have built your program with coverage and run it  (I use cmake and build into build_ifx_debug)
GCOV_TOOL="$(pwd)/llvm-cov-gcov"    # absolute path (see note above)
lcov --gcov-tool "$GCOV_TOOL" --capture --directory build_ifx_debug --output-file coverage.info
lcov --gcov-tool "$GCOV_TOOL" --remove coverage.info '*/build_ifx_debug/*' '/usr/*' \
  --output-file coverage.filtered.info
genhtml coverage.filtered.info --output-directory coverage_html
Apparently, gcovr will accept a multi-word tool. So, you could use it with --gcov-executable "${CMPLR_ROOT}/bin/compiler/llvm-cov gcov".  I don't have gcovr installed, so haven't verified this.
In theory, you could also do this on Windows.  The LLVM tools are in C:\Program Files (x86)\Intel\oneAPI\compiler\latest\bin\compiler. There are various ways of using lcov on Windows - a web search should provide the relevant information.
Fran-Martinez
Thanks Mark for the reponse.
Knowing that ifx alredy provides code coverage support is very interesting and useful.
Unfortunatelly I have not been able to pass the first step.
I have downloaded and installed the latest oneapi version (2026.1). I run Ubuntu 26.04 LTS on VMware.
Compiling with --coverage does not seem to generate an executable that produces any coverage information. I run on a single fortran file (attached) with the command:
      /opt/intel/oneapi/compiler/2026.1/bin/ifx -rpath $LD_LIBRARY_PATH -L $LD_LIBRARY_PATH -lintlc --coverage fast_square_root.f90
With the additional options to resolve for requested libraries.
Once I run the generated executable I was expecting sime .gcno/.gcda or of the like files.
Maybe I miss an environment variable or looking in the wrong place. Is there any additional compiler option missing?
Thanks and best regards
Fran
Mark_Lewy
Hi Fran,
You need to compile your program with debug information, optimisation doesn't get on with code coverage.
ifx -g --coverage fast_square_root.f90
ifx: remark #10440: Note that use of a debug option without any optimization-level option will turnoff most compiler optimizations similar to use of '-O0'
./a.out
3.615507630310937E-002
3.615507630310936E-002
35.000
54.000
(I edited n to make it much smaller than in the original)
ls -al
drwxrwxrwx 1 lewym lewym 512 Jul 27 2026 .
drwxrwxrwx 1 lewym lewym 512 Jul 27 13:50 ..
-rwxrwxrwx 1 lewym lewym 616744 Jul 27 13:59 a.out
-rwxrwxrwx 1 lewym lewym 1563 Jul 27 13:52 fast_square_root.f90
-rwxrwxrwx 1 lewym lewym 108 Jul 27 2026 fast_square_root.gcda
-rwxrwxrwx 1 lewym lewym 988 Jul 27 13:59 fast_square_root.gcno
The gcda and gcno files are the ones you should see when coverage is enabled.
ifx --version
ifx (IFX) 2025.3.3 20260319
Copyright (C) 1985-2026 Intel Corporation. All rights reserved.
I'd be surprised if this was no longer working in 2026.1
Fran-Martinez
Nice. I got it working now. I did not think of the need to compile with debugging.
I also got it running in windows with Visual Studio 2026. Here I had to manually add clang_rt.profile-x86_64.lib because the compiler does not include it automatically in the link step, even including --coverage flag at compile and link time.
Both in windows and linux with ifx 2026.1
Cheers,
Fran
