29430 Discussions
Colorization lost in Fortran files in Visual Studio 2022
ferrad1
I upgraded to VS 2022 17.4.4 / Intel Fortran Version 2021.8.0 Build 20221119_000000 a few weeks ago.  All went smoothly, but yesterday I lost colorization in the F90 files.  All just black on white.  I decided to uninstall and reinstall Fortran but to no avail.  My process was to uninstall Base Toolkit 2023 and HPC Toolkit 2023 (I also have 2022.2 versions from September last year, they must be from a previous version).
The installation procedure is not that clear on https://www.intel.com/content/www/us/en/developer/tools/oneapi/fortran-compiler.html
It seems "Get It Now" is the item to click.  This installed HPC only.  The colorization issue was still there.  I then uninstalled again and went back to this website and delved deeper to find the Base Toolkit installation, which I installed, and then the HPC again.  But I still have the colorization issue.  In fact there no Fortran entries in Tools -> Options -> Fonts and Colors -> Text Editor -> Display Items.
PeterPriestley
I had the same experience, but when started VS2022 with 'Run As Administrator' the Intel Fortran integrations worked and the code window was colourized.  Perhaps you only need to do this first time as mine now seems to work either way.
Barbara_P_Intel
When you updated to VS 2022 did you follow the instructions to configure VS correctly before you installed the HPC Toolkit?
Did you have color when you initially installed VS 2022 17.4.4 / Intel Fortran Version 2021.8.0? If so, what changed?
PeterPriestley
ferrad1
Perfect!  Worked like a charm, thanks !   ... Intel do your trick
