29648 Discussions
catastrophic error: Internal Compiler Error: Ref module: ffe_ccvt.c
V-T
Consider the following minimal working example:
module lib
    type t
        real,allocatable::v(:)
    end type
contains
    type(t)function f(o,i)
        class(t),intent(in)::o
        integer,intent(in)::i
        f=t(REAL(i)*o%v)  ! any function instead of `REAL` can be here; compiles with `f=t(o%v*REAL(i))`
    end
end
program prog
    use lib
end
Compilation of this code with the Intel compiler (ifort 2021.8.0 and ifx 2023.0.0 on Ubuntu 18.04.2 LTS) and without any flags fails with the following output:
test.F90(9): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
test.F90(9): catastrophic error: Internal Compiler Error: Ref module: ffe_ccvt.c
compilation aborted for m.F90 (code 1)
But changing the order of multiplicands in line 9 solves the problem.
Barbara_P_Intel
Good news! Both ifx and ifort compile this reproducer successfully with the compilers that will be released in the spring.
There will be an announcement on this Forum (and others) when it is available.
Barbara_P_Intel
