29643 Discussions
Output window missing project number
ferrad1
VS 2022 17.4.4 / Intel Fortran 2021.8.0
The VS Output window during a build used to prepend every line of output with the number of the project and >, so one could see which project a particular message applied to.  That project number has now gone, which makes it very difficult to identify where the problem is coming from, since projects are built in parallel, and the output lines are therefore interspersed.
Is that a project or solution setting now?
