Command Line Link Error
moranding
I am trying to link a fortran routine with a DLL using the command line DF from a DOS window. I keep getting a LINK1181 error saying "cannot open the input file dfor.lib". This is the library used for console mode. Even if I use /NODEFAULTLIB:dfor.lib or /NODEFAULTLIB:dfconsole, I still get this error. I am running CVF on an XP Xeon machine. Any help would be appreciated.
TIA
Did you start your session with the "Fortran Command Prompt" shortcut in the Visual Fortran program group? This defines various environment variables you need.
