Hello everybody.
Where could I find the exhaustive list of the command line options of the Intel Fortran compiler?
I only have found the few examples in https://software.intel.com/es-es/node/510158 . But, where is the rest? Maybe it is obvious and I missed something...
Thanks in advance and best regards.
If you open a DOS-box that has its environment set to run the compiler, then do:
ifort -help
This gives you an overview and an explanation of the command-line options.
Oops. Yes, I was missing something. Thanks!
I typically issue
ifort -help>ifort.txt
notepad ifort.txt
Then keep the notepad window open as I can now scroll the entire contents (as well as search).
Jim Dempsey
Go to https://software.intel.com/en-us/compiler_15.0_ug_f and click on the link shown for "Compiler Options".
We are using the version 14 but I guess most in the web will be valid.
Thanks everybody.
Gustavo Baños
The documentation for 14.0, which is installed with the compiler on your PC, has the same general topic with detailed descriptions of all options - more than what the -help shows.
Hello Steve. Yes, you are right, at Compiler Reference > Compiler Options. Thanks again.
