Common block and struct in a DLL
demo_360
Actually I am developing a mixed program With Fortran and C++. The fortran code was in a DLL and the C++ code was a MFC application.
I actually try to bind my common block on struct, but it doesn't work. I want to do this because I have a lot of information to share between the DLL and the MFC application.
Here's what I actually have.
In my main Class(Refra.h)I have some struct Declaration who look like this:
extern "C" struct START{
double XD;
double YD;
double ALPHAD;
float BETAD[2];
float WAVE_HEIGHT;
float CFR;
}START;
extern "C" struct END{
double X_END;
double Y_END;
double ALPHA_END;
double BETA_END[2];
double SHORE_LEN[2];
double SHORE_LOC[2];
double SEA_SIDE[2];
double CFR_END;
double D_HALLER;
bool BEHIND_BW;
}END;
In an other class (RefraDoc.h) I Create some instance of the struct:
struct END m_end;
struct START m_start;
In my fortran DLL I have this common block in my subroutine.
COMMON/START/ XD,YD,ALPHAD,BETAD(2),WAVE_HEIGHT,CFR
COMMON/END/ X_END,Y_END,ALPHA_END,BETA_END(2),SHORE_LEN(2),SHORE_LOC(2),SEA_SIDE(2),CFR_END,D_HALLER,BEHIND_BW
I have try a lot of things to share them but no one works. What is the good way to share my Fortran common block with my C++ Struct?
Thanks in advance for your help.
Demo_360
Jugoslav_Dujic
Valued Contributor II
Do you have
!DEC$ATTRIBUTES DLLEXPORT:: START
!DEC$ATTRIBUTES DLLEXPORT:: END
statements in your Fortran code?
demo_360
Yep #:(
and it doesn't seems to work... Cause I have set some variable of my struct (C++) and I don't have the value in my common block when i call my Fortran subroutine.
I need a kind of bidirectional setting, if i set something in my C++ I want to have it in my Fortran, And if I set in my Fortran code, I want it in my C++.
Demo_360
demo_360
Here is the answer...
The struct need to be declared like this in you main .h class:
extern "C" _declspec(dllimport) struct START{
double XD;
double YD;
double ALPHAD;
float BETAD[2];
float WAVE_HEIGHT;
float CFR;
}Start;
in your fortran subroutine your Common will look like this and then you DLLEXPORT your common block like this:
!DEC$ ATTRIBUTE DLLEXPORT ::START
To use your struct in your MFC application only use the name you gave to yor struct, in this case Start.
Like this you will be able to read and set the value value of the common block from your MFC apps, And you will be able to read and set to the value of the struct from you fortran subroutine...
ayaz
I am working on a mixed programing project, I am using CVF6.6B and MS VC++ 6.0. In my project the Fortran computation part is in a DLL and I am developing a GUI using MFC. I have the similar stiuation, therefore I followed as descried here to share varibels defined in the common block of Fortran and in a structure at C++ side.
But when I try to set values of my varibles at C++ side, compiler gives error messages, as if those varibels are not defined at atll and are unidentified.
Would someone please explain, how to set the value of varibales, say XD at C++ side?
Jugoslav_Dujic
You must refer to them as [StructureName].[MemberName], not just as [MemberName]. Thus, for the example above,
you have to use Start.XD = something.
Jugoslav
ayaz
Thank you Jugoslav for the answer. Actually I am still facing the problem of unidentified variable names during compile time. I have a very simple test program, following are my codes:
In Fortran DLL
the file "DAT.FOR" contains variable declarations:
integer PP
integer New
integer Yes
real PI
logical OK1
logical Lgcl
the file "mockfortran.for":
subroutine mockfortran()
implicit none
include 'dat.for'
!DEC$ ATTRIBUTES DLLEXPORT:: mockfortran
COMMON/ START/ PP,New,Yes,PI,OK1,Lgcl
!DEC$ ATTRIBUTE DLLEXPORT:: START
PP = 10
PP= 100*PP
Yes= 42
PI = 3.141
New = Yes* PP
Lgcl = .false.
if (10 .gt. 200) then
OK1 = .true.
else
OK1 = .false.
endif
end subroutine mockfortran
At C++ side, (using MFC)
In "Start.h", contains structure for the common blcok varibales:
extern "C" __declspec(dllimport) struct START {
int PP;
int New;
int Yes;
double PI;
bool OK1;
bool Lgcl;
} Start ;
In "MockDlg.cpp" file:
# include "Start.h"
// For calling fortran subroutine, in mockfortran.FOR
extern "C" __declspec(dllimport) void _stdcall mockfortran();
ofstream theOutputFile("output.txt"); // the output text file
mockfortran(); // Fortran subroutine call
theOutputFile << PI << endl ;
theOutputFile << PP << endl ;
theOutputFile << OK1<< endl ;
theOutputFile << Lgcl<< endl ;
At the compile time, the error message says the identifiers PI, PP, OK1 and Lgcl are undefined.
What could be the reason?
Jugoslav_Dujic
Because you need:
theOutputFile << Start.PI << endl ;
theOutputFile << Start.PP << endl ;
theOutputFile  << Start.OK1<< endl ;
theOutputFile  << Start.Lgcl<< endl ;
Jugoslav
ayaz
Hi
Thanks again for your answer, this has solved the compile time error. But at the link time, the error message says:
MockDlg.obj : error LNK2001: unresolved external symbol __imp__Start
Debug/MockC.exe : fatal error LNK1120: 1 unresolved externals
Error executing xilink6.exe"
Could you please help on this, how to fix this?
Jugoslav_Dujic
Ah, I overlooked that -- CVF by default exports common (and other names) in uppercase. You should be fine if you replace structure name with START. (Don't forget to link YourDll.lib with C++ host).
Jugoslav
ayaz
Thank you very much Jugoslav, it worked.
