29560 Discussions
Communicating between Fortran TYPE and C++ structure
morethanair
Hi, all.
I wrote some test code using C DLL in Fortran.
I tested the memory matching between Fortran TYPE and C structure.
MODULE mod
TYPE test_t
INTEGER a
INTEGER b
INTEGER,POINTER::c(:)
REAL d
INTEGER e
INTEGER f
INTEGER g
END TYPE
END MODULE mod
PROGRAM main
USE mod
IMPLICIT NONE
TYPE(test_t) input
input%a=1
input%b=2
ALLOCATE(input%c(2))
input%c(1)=3
input%c(2)=4
input%d=5.5
input%e=6
input%f=7
input%g=8
call TEST(input)
END PROGRAM main
I simply put some values in Fortran code, and check it in C code like below.
typedef struct _test_t
int a;
int b;
int* c;
float d;
int e;
int f;
int g;
} test_t;
extern "C" __declspec(dllexport) void TEST(test_t* member)
printf("%f",member->d);
Before the pointer, the value are all right (a=1,b=2,c[0]=3,c[1]=4), but after then the values are distorted.
d=5.605e-045#DEN
e=-4
f=5
g=1
I guess the size of pointer in Fortran and C is different.
Anybody knows how to solve this problem?
Thank you.
ZlamalJakub
New Contributor III
If you compile 32 bit app, pointer size is 4 bytes does not matter on language.
I think that problem is that you use fortran pointer and not integer pointer. (I do not use fortran pointers so i do not have experience with this.
1. Are the values of a and b correct. if yes there is probably problem with c.
2. Try to put c at the end of structure.
Jakub
morethanair
Thank you for the reply.
I tried to put the pointer at the end of the structure, and it works of course.
The problem is that I should use the structure containing several pointers.
To the first pointer, it works properly, but it has wrong values after that.
Is there any other idea?
ZlamalJakub
New Contributor III
Try following code
MODULE mod
TYPE test_t
INTEGER a
INTEGER b
integer d
INTEGER e
INTEGER f
INTEGER g
END TYPE
END MODULE mod
PROGRAM main
USE mod
IMPLICIT NONE
TYPE(test_t) input
integer*4 array(10)
pointer (parray,array)
input%a=1
input%b=2
input%d=5
input%e=6
input%f=7
input%g=8
parray=loc(input)
write(*,*) "size of input ",sizeof(input)
write(*,*) "values",array
input%c(1)=3
input%c(2)=4
parray=loc(input) ! associate pointer
write(*,*) "a address",loc(input.a)
write(*,*) "b address",loc(input.b)
write(*,*) "c address",loc(input.c)
write(*,*) "d address",loc(input.d)
write(*,*) "e address",loc(input.e)
END PROGRAM main
from addresses of members of structure (at the end of code) can be seen, that your structure is not in continuous block of memory (as is assumed by C code). You cannot use fortran pointers in structure if it is passed to C code
I modified member d to be integer to have the same type as array
Jakub
ZlamalJakub
New Contributor III
Try this code (it should work however I do not tested it).
MODULE mod
use ifwinty
TYPE test_t
INTEGER a
INTEGER b
integer(HANDLE) c
integer d
INTEGER e
INTEGER f
INTEGER g
END TYPE
END MODULE mod
PROGRAM main
USE mod
IMPLICIT NONE
TYPE(test_t) input
integer*4,allocatable :: c(:)
input%a=1
input%b=2
input%d=5
input%e=6
input%f=7
input%g=8
ALLOCATE(c(2))
c(1)=3
c(2)=4
input%c=loc(c) ! update pointer to data
call ...
END PROGRAM main
problem is that You should manage allocatable arrays separately of input structure and only update pointer to data input%c
Jakub
ZlamalJakub
New Contributor III
From the difference of adresses input.b amnd input.d (which should be 8 bytes - 4bytes of size a and 4bytes of size c) can be seen that FORTRAN adds another 32 bytes for pointer handling.
May be if you use your c structure like
typedef struct _test_t{
int a;
int b;
int* c;
int cpointerdummy[8]; // extra 8*4 bytes for FORTRAN pointer
float d;
int e;
int f;
int g;
} test_t;
your code should work as it was on the beginning
Jakub
IDZ_A_Intel
INTEGER,POINTER::c(:) isn't going to match anything reasonable in C, as Fortran will insert an array descriptor with many fields. I suggest instead using the type C_PTR from ISO_C_BINDING and assign its value using the C_LOC function from the same module. This will match what you expect in C.
