29285 Discussions
Comparison operator overridden in extending types
Bálint_A_
Dear All,
I have some problems with the == operator when using Intel 15. Below the self containing example demonstrating the issue. IMHO, the comparison between instances of the derived types calls the wrong routine (the one of the base type instead of the overriden one of the extending type), when the instances are accessed via class pointers of the base type. Other compilers do it differently, and although I do not have a detailed knowledge of the standard, the behaviour feels incorrect. Any views on that?
Bálint
module testmod
  implicit none
  type :: Base
  contains
    procedure :: isEqualTo => Base_isEqualTo
    generic :: operator(==) => isEqualTo
  end type Base
  type, extends(Base) :: Extended
    integer :: ii
  contains
    procedure :: isEqualTo => Extended_isEqualTo
  end type Extended
contains
  function Base_isEqualTo(this, other) result(isEqual)
    class(Base), intent(in) :: this
    class(Base), intent(in) :: other
    logical :: isEqual
    print *, "Base_isEqualTo invoked"
    isEqual = .false.
  end function Base_isEqualTo
  function Extended_isEqualTo(this, other) result(isEqual)
    class(Extended), intent(in) :: this
    logical :: isEqual
    print *, "Extended_isEqualTo invoked"
    select type (other)
    class is (Extended)
      isEqual = (this%ii == other%ii)
    class default
      isEqual = .false.
    end select
  end function Extended_isEqualTo
end module testmod
program test
  use testmod
  implicit none
  type(Extended), target :: ext1, ext2
  class(Base), pointer :: pBase1, pBase2
  logical :: isEqual
  ext1%ii = 1
  ext2%ii = 1
  pBase1 => ext1
  pBase2 => ext2
  isEqual = (pBase1 == pBase2)
  print *, "Equal?", isEqual
end program test
FortranFan
The code seems to work as expected using Intel Fortran compiler 16.0, initial release.  Perhaps you can consider upgrading your compiler?
FortranFan
Bálint_A_
Thanks for testing it. Apparently, I'll have to upgrade then. :-)
