Dear All,
I have some problems with the == operator when using Intel 15. Below the self containing example demonstrating the issue. IMHO, the comparison between instances of the derived types calls the wrong routine (the one of the base type instead of the overriden one of the extending type), when the instances are accessed via class pointers of the base type. Other compilers do it differently, and although I do not have a detailed knowledge of the standard, the behaviour feels incorrect. Any views on that?
Bálint
module testmod
implicit none
type :: Base
contains
procedure :: isEqualTo => Base_isEqualTo
generic :: operator(==) => isEqualTo
end type Base
type, extends(Base) :: Extended
integer :: ii
contains
procedure :: isEqualTo => Extended_isEqualTo
end type Extended
contains
function Base_isEqualTo(this, other) result(isEqual)
class(Base), intent(in) :: this
class(Base), intent(in) :: other
logical :: isEqual
print *, "Base_isEqualTo invoked"
isEqual = .false.
end function Base_isEqualTo
function Extended_isEqualTo(this, other) result(isEqual)
class(Extended), intent(in) :: this
logical :: isEqual
print *, "Extended_isEqualTo invoked"
select type (other)
class is (Extended)
isEqual = (this%ii == other%ii)
class default
isEqual = .false.
end select
end function Extended_isEqualTo
end module testmod
program test
use testmod
implicit none
type(Extended), target :: ext1, ext2
class(Base), pointer :: pBase1, pBase2
logical :: isEqual
ext1%ii = 1
ext2%ii = 1
pBase1 => ext1
pBase2 => ext2
isEqual = (pBase1 == pBase2)
print *, "Equal?", isEqual
end program test
The code seems to work as expected using Intel Fortran compiler 16.0, initial release. Perhaps you can consider upgrading your compiler?
Thanks for testing it. Apparently, I'll have to upgrade then. :-)
