Compilation Failure Error 10298 IFORT
acar
I have moved computers and have downloaded new version of VS2015 and Intel Fortran.  When compiling my project I get the following error:
Severity Code Description Project File Line Suppression State
Error error #10298: problem during post processing of parallel object compilation ifort
I wonder if anyone might help me through this issue?
IanH
Is there another error listed in the build sequence prior to this one?
acar
The following error was also there IanH:
Error Severe: No such file or directory fortcom
IanH
Can you compile a simple "hello world" fortran file?  That error suggests an installation problem to me.
acar
Thanks IanH.  There are other fortran projects in the VS solution and they compile perfectly well so I take from that that fortran has been correctly installed.  Any other suggestions welcome...
IanH
It would appear something about that project is mucking things up.
Perhaps raise a ticket Intel Support and get them to have a look.
