29617 Discussions
Compilation error #6866: Dotted string is neither a defined operator nor a structure component.
Paul_v_2
First off, my compiler and some platform details:
$ ifort --version
ifort (IFORT) 16.0.1 20151021
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
$ uname -a
Linux tfe04 2.6.32-431.29.2.el6.x86_64 #1 SMP Sun Jul 27 15:55:46 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
(It's a login node of a supercomputer)
I have an example of some code (shown below) that does not compile, exhibiting error #6866 which, based on my searches of these forums, should have been fixed in an earlier version.
MODULE my_define
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: my_type
  TYPE :: my_type
    INTEGER :: j = 0
    INTEGER :: i = 0
  CONTAINS
    PRIVATE
    PROCEDURE :: Equal
    PROCEDURE :: NotEqual
    PROCEDURE :: Compare
    GENERIC, PUBLIC :: OPERATOR(==) => Equal
    GENERIC, PUBLIC :: OPERATOR(/=) => NotEqual
    GENERIC, PUBLIC :: OPERATOR(.Compare.) => Compare
  END TYPE my_type
CONTAINS
  ELEMENTAL FUNCTION Equal( x, y ) RESULT( is_equal )
    CLASS(my_type), INTENT(IN) :: x, y
    LOGICAL :: is_equal
    is_equal = (x%j == y%j) .AND. (x%i == y%i)
  END FUNCTION Equal
  ELEMENTAL FUNCTION NotEqual( x, y ) RESULT( not_equal )
    LOGICAL :: not_equal
    not_equal = .NOT. (x == y)
  END FUNCTION NotEqual
  FUNCTION Compare( x, y ) RESULT( is_equal )
    LOGICAL :: is_equal
    is_equal = .TRUE.
    IF ( x%j /= y%j ) THEN
      print *, 'J component of my objects are different'
      is_equal = .FALSE.
    END IF
    IF ( x%i /= y%i ) THEN
      print *, 'I component of my objects are different'
      is_equal = .FALSE.
    END IF
  END FUNCTION Compare
END MODULE my_define
! Test program for module
PROGRAM Test_my
  USE my_define, ONLY: my_type
  IMPLICIT NONE
  LOGICAL :: is_equal
  TYPE(my_type) :: my, my_copy
  my%j = 1
  my_copy = my
  IF ( my /= my_copy ) THEN
    is_equal = my .Compare. my_copy
  END IF
END PROGRAM Test_my
When I compile the above I get:
$ ifort one_type.f90
one_type.f90(67): error #6866: Dotted string is neither a defined operator nor a structure component.   [COMPARE]
compilation aborted for one_type.f90 (code 1)
As far as I can tell, my test code is correct and standard conforming. Am I missing something?
The same code builds and runs fine using gfortran 4.9.x
Thanks for any information
cheers,
paulv
At first glance I agree it should compile. We'll check it out - thanks.
FortranFan
Intel compiler seems to have the problem with the procedure name being the same as the string between the dotted operators; as a check, try a different procedure name, say Compare_.
Paul_v_2
It appears you are correct. See below:
$ diff one_type.f90 one_type_renamed.f90
--- one_type.f90	2016-01-25 12:51:37.408615000 +0000
+++ one_type_renamed.f90	2016-01-25 12:51:06.914900000 +0000
@@ -10,10 +10,10 @@
     PRIVATE
     PROCEDURE :: Equal
-    PROCEDURE :: Compare
+    PROCEDURE :: Compare_
-    GENERIC, PUBLIC :: OPERATOR(.Compare.) => Compare
+    GENERIC, PUBLIC :: OPERATOR(.Compare.) => Compare_
   END TYPE my_type
 CONTAINS
@@ -32,7 +32,7 @@
-  FUNCTION Compare( x, y ) RESULT( is_equal )
+  FUNCTION Compare_( x, y ) RESULT( is_equal )
     LOGICAL :: is_equal
     is_equal = .TRUE.
@@ -44,7 +44,7 @@
       is_equal = .FALSE.
     END IF
-  END FUNCTION Compare
+  END FUNCTION Compare_
$ ifort one_type_renamed.f90
No compilation errors. Woohoo!
Obviously I would still like the compiler bug to be fixed, but thanks to FortranFan for the work-around! (and pointing out exactly what the problem was)
cheers,
paulv
Escalated as issue DPD200381107. I will reply here when there is news, but you do have a good workaround.
Paul_v_2
Thanks Steve
This has been fixed in the compiler source, but I don't yet know when the fix will appear. When I get more information I will let you know.
The fix should appear in the 17.0 product release, or if not, Update 1.
