29627 Discussions
Compilation error for Win32 config
ferrad1
I am adding Win32 configuration to my x64 project, but am getting a compile error for one file:
ctime.f90(51): error #7881: This module file was generated for a different platform or by an incompatible compiler or compiler release. It cannot be read. [ISO_FORTRAN_ENV]
The command line is:
ifort /c /nologo /fpp /debug:full /MP /Od /recursive /reentrancy:threaded /real_size:64 /Qauto /Qtrapuv /Qinit:snan /Qinit:arrays /fpe:0 /fpconstant /object:"..\..\tmp\nlib\Debug\Win32\\" /traceback /check:pointer /check:bounds /check:uninit /check:arg_temp_created /check:stack /libs:dll /threads /dbglibs /c ctime.f90
The (trimmed) code is:
      subroutine vers()
      use iso_fortran_env
      character(30) stamp
      call compile_time(stamp)
      end
mecej4
Do you have the file ...\OneAPI\compiler\latest\windows\compiler\include\iso_fortran_env.modintr present? If so, what is its size and what is its date?
The OneAPI include directory should contain the source file iso_fortran_env.f90. Compiling that file should produce the module file iso_fortran_env.mod, which you can then use to build the rest of your project. You will have to arrange the Visual Studio project options so that the compiler will find the module file.
ferrad1
Yes I have them:
C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\ia32
11/19/2022 12:56 AM 7,300 iso_fortran_env.modintr
C:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\intel64
11/18/2022 09:13 PM 8,492 iso_fortran_env.modintr
I have included iso_fortran_env.f90 in my project.  It compiles fine. But I still get the error:
Something that is strange is that if I put a compiler directive around it:
!DEC$ IF DEFINED(_WIN64)
      use iso_fortran_env
!DEC$ ENDIF
the Win32 build still brings up the error.
