29375 Discussions
Compilation error on Mac :Undefined symbols for architecture x86_64
E_K_
Hi
I'm using Intel Fortran version 14.0.2 20140121 on Mac OS X and Xcode 6.1.1.
After Installing and sourcing files like
source /opt/intel/bin/compilervars.sh intel64
source /opt/intel/mkl/bin/intel64/mklvars_intel64.sh
tried to compile a test file (Hello world) and got the following error:
Undefined symbols for architecture x86_64:
  "__Unwind_Backtrace", referenced from:
      _tbk_trace_stack in libirc.a(tbk_backtrace.o)
  "__Unwind_ForcedUnwind", referenced from:
  "__Unwind_GetIP", referenced from:
      _tbk_stop_unwind_callback in libirc.a(tbk_backtrace.o)
      _backtrace_callback in libirc.a(tbk_backtrace.o)
  "__Unwind_GetRegionStart", referenced from:
ld: symbol(s) not found for architecture x86_64
I've read that this combination of OS and Xcode is not supported by the version 14,
but as I saw a similar error when I compiled the same file with gfortran,
I think this might not be due to the combination problem.
I'm glad if someone could find how to fix this error.
TimP
Did you check whether libunwind is linked.  If not, does specifying it help?
E_K_
Thank you for your comment !
I couldn't find libunwind.a in /opt/intel/lib/intel64.
There is libunwind.h in an irreverent folder, but I guess this is for another compiler.
JVanB
Valued Contributor II
I know nothing about Mac, however it does name libraries more like libunwind.dylib than libunwind.a . Maybe you can modify your search accordingly.
Do you have gcc installed? That is required. Missing gcc could cause this error.
Kevin_D_Intel
I have not been able to coax ld into shedding light on where those external references are resolved so I cannot tell which location might be used. On our Mac running OS X 10.10 (Yosemite) with Xcode 6.1 it has:
/usr/lib/system/libunwind.dylib
-OR-
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk/usr/lib/system/libunwind.dylib
I somewhat suspect the latter is used since the compiler-driver includes most of the path to the latter copy on the ld command-line for the -syslibroot argument.
i.e.
    -syslibroot \
    /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk \
Along the lines of Steve’s comment, I was wondering whether a trivial C/C++ program will compile and link.
Also, did you install the Intel 14.0 release after the Xcode 6.1 install?  If not, you should reinstall the Intel 14.0 release.
Kevin_D_Intel
I just confirmed that it is the version found under the -syslibroot path. You can compile using the ifort -dryrun option to see what path the compiler uses for -syslibroot.
E_K_
Thank you so much for the people who kindly commented!
The one causing the trouble was gcc.
I could compile a c program, but after I installed another gcc via macports,
the error on ifort disappeared.
Thank you all again!
Kevin_D_Intel
Interesting. I'm not sure what the root cause was but am glad you were able to resolve this.
