29565 Discussions
Compile errors for Do-loops that worked fine in CVF
TommyCee
The following snippet is some code that worked fine in CVF.  I'm getting these errors for the last 5 nested Do-loops:
error #8093: A do-variable within a DO body shall not appear in a variable definition context.
error #6511: This DO variable has already been used as an outer DO variable in the same nesting structure.
[bash]! DETERMINE PERCENTAGES:
 290 Do I=1,16
       Do J=1,19
       WSfreq(I,J)=WSfreq(I,J)/TOTAL
       DPfreq(I,J)=DPfreq(I,J)/TOTAL
       DBfreq(I,J)=DBfreq(I,J)/TOTAL
       VSfreq(I,J)=VSfreq(I,J)/TOTAL
     EndDo
     Do I=1,16
       Do J=1,11
       RHfreq(I,J)=RHfreq(I,J)/TOTAL
     EndDo
     Do I=1,16
       Do J=1,7
       STfreq(I,J)=STfreq(I,J)/TOTAL
     EndDo
     Do I=1,16
       Do J=1,18
       FKfreq(I,J)=FKfreq(I,J)/TOTAL
     EndDo
     Do I=1,16
       Do J=1,96
       PLfreq(I,J)=PLfreq(I,J)/TOTAL
       PHfreq(I,J)=PHfreq(I,J)/TOTAL
     EndDo
     Do I=1,96
       Do J=1,3
       Do K=1,3
       FREQ(I,J,K)=FREQ(I,J,K)/TOTAL
     EndDo[/bash]
I have never seen this before.  'I' is only a dummy variable.  Why is there no complain about the 1st nested Do-loop?  It's practically identical.
Any help is appreciated.
IanH
The difference is that the first nested do loop uses J as its index variable.
Re-indenting your code to clarify:
[fortran] 290  Do I=1,16        !## 1
        Do J=1,19
        EndDo
        Do I=1,16     !## 2
          Do J=1,11
          EndDo
          Do I=1,16   !## 3
            Do J=1,7
            EndDo
[/fortran]
The outer loop starting at ## 1 uses i for an index variable.  You are re-using that variable for the nested loops at ## 2 and ## 3, etc.  The language rules do not permit that - an index variable in a do loop can't be changed by any statements inside the do loop (which includes other do statements).
Consider using variable names such as i1, i2, i3, etc for each level of nesting.
DavidWhite
Valued Contributor II
"End Do" only terminates the current loop, not nested loops.
Should your code really be:
Do I ...
    Do J
    End Do
End Do
etc.
David
TommyCee
Thanks Ian.  I guess I'm a little new to F90 "rules" and I never dreamed of that rule!  I won't even begin to ponder the logic or value of it.  But when you say "which includes other do statements", I guess you mean any others in the present scope.  In other words, this renaming of the outer dummy variable (as you will see below for the prestent case - it compiled OK) applies to all such DO-loops within a given scope, right?
 290 Do I=1,16
       Do J=1,19
     EndDo
     Do I1=1,16
       Do J=1,11
       RHfreq(I1,J)=RHfreq(I1,J)/TOTAL
     EndDo
     Do I2=1,16
       Do J=1,7
       STfreq(I2,J)=STfreq(I2,J)/TOTAL
     EndDo
     Do I3=1,16
       Do J=1,18
       FKfreq(I3,J)=FKfreq(I3,J)/TOTAL
     EndDo
     Do I4=1,16
       Do J=1,96
       PLfreq(I4,J)=PLfreq(I4,J)/TOTAL
       PHfreq(I4,J)=PHfreq(I4,J)/TOTAL
     EndDo
     Do I5=1,96
       Do J=1,3
       Do K=1,3
       FREQ(I5,J,K)=FREQ(I5,J,K)/TOTAL
     EndDo
     Do 360 I6=1,10
       Fogs(I6)=Fogs(I6)/TOTAL
 360 EndDo[/bash]
John_Campbell
New Contributor II
I don't think your original code worked fine with CVF. Note the changes so that each DO start is terminated by it's own END DO.  Using array syntax might simplify your code and remove the multiple DO loops.
 290 Do I=1,16
       Do J=1,19
       EndDo
     END DO
     Do I=1,16
       Do J=1,11
       EndDo
     END DO
     Do I=1,16
       Do J=1,7
       EndDo
     END DO
     Do I=1,16
       Do J=1,18
       EndDo
     END DO
     Do I=1,16
       Do J=1,96
       EndDo
     END DO
     Do I=1,96
       Do J=1,3
         Do K=1,3
         EndDo
       END DO
     END DO
[/bash]
IanH
I meant other do statements using i that are in the same scope that are nested inside a do that uses i as the control variable.
So your latest snippet is ok - you don't re-use i as a control variable inside the construct that starts with the statement labelled 290.  Similarly, all the do loops that use j are not nested inside each other.
This isn't new to F90 - Fortran 66 and Fortran 77 have the same restriction.  What's changed is the compiler's ability to detect mistakes made by the programmer.
jimdempseyatthecove
Tommy,
I think your first issue derived from you making a conversion from F77:
        Do 5000 I=1,96
          Do 5000 J=1,3
          Do 5000 K=1,3
5000 CONTINUE
And replaced the one CONTINUE statement with one ENDDO statement.
The above loop in f90 form using ENDDO requires no lable number (5000) and one ENDDO per DO.
Jim Dempsey
TommyCee
All very interesting.
John, I assure you that this worked perfectly w/ CVF.  Of the 2 avenues for remedy here, John's seemed the simplest.  However, I tried it and got the same compiler errors!
The only remedy that worked was Ian's.  It appears that the nested DO-loops can share the same EndDo.
As I say, I have never seen this kind of conflict before among independent (self-contained) nested DO-loops within a scoping unit - in this case, a subroutine.  But I'll do what I have to do to make the compiler happy.
BTW, the I-index for another Do-loop shown in L42-44 (not a nested DO-loop) also had to be renamed, as follows:
 290 Do I=1,16
       Do J=1,19
     EndDo
     Do I1=1,16
       Do J=1,11
       EndDo
     EndDo
     Do I2=1,16
       Do J=1,7
       EndDo
     EndDo
     Do I3=1,16
       Do J=1,18
       EndDo
     EndDo
     Do I4=1,16
       Do J=1,96
       EndDo
     EndDo
     Do I5=1,96
       Do J=1,3
       Do K=1,3
       EndDo
     EndDo
     Do 360 I6=1,10
 360 EndDo[/bash]
TommyCee
I take one thing back:
"It appears that the nested DO-loops can share the same EndDo."
This appears not to be the case after all w/ F90.
Arjen_Markus
If it were, then this code would be ambiguous:
do i = 1,10
    do j = 1,20
         write(*,*) i+j
    enddo
    do j = 1,20
         write(*,*) i-j
    enddo
Where should the first loop be terminated?
With FORTRAN 77 there is an indication of the label that the do-loop ends with.
That label can be shared, as it is the do statement that determines the end, not the label.
Arjen
CVF does not accept the code in the original post.
[plain]C:Projects>df -c t.f90
Compaq Visual Fortran Optimizing Compiler Version 6.6 (Update C)
Copyright 2003 Compaq Computer Corp. All rights reserved.
t.f90
t.f90(14) : Error: This DO variable has already been used as an outer DO variabl
     Do I=1,16
t.f90(19) : Error: This DO variable has already been used as an outer DO variabl
     Do I=1,16
t.f90(24) : Error: This DO variable has already been used as an outer DO variabl
     Do I=1,16
t.f90(29) : Error: This DO variable has already been used as an outer DO variabl
     Do I=1,16
t.f90(35) : Error: This DO variable has already been used as an outer DO variabl
     Do I=1,96
t.f90(36) : Error: An unterminated block exists.
       Do J=1,3
t.f90(35) : Error: An unterminated block exists.
     Do I=1,96
t.f90(29) : Error: An unterminated block exists.
     Do I=1,16
t.f90(24) : Error: An unterminated block exists.
     Do I=1,16
t.f90(19) : Error: An unterminated block exists.
     Do I=1,16
t.f90(14) : Error: An unterminated block exists.
     Do I=1,16
t.f90(6) : Error: An unterminated block exists.
 290 Do I=1,16
[/plain]
TommyCee
Thanks for your response, Arjen.  In CVF, the answer to you question would implicitly be L4 (see below).  I believe I have seen this behavior work fine over and over again but I stress - not appling strict F90 standards.  In IVF, especially applying F90 standards (Project|Properties|Fortran|Diagnostics: Warn for Non-standard Fortran - Fortran 90), each DO-loop must have its own termination.
[bash]do i = 1,10
    do j = 1,20
         write(*,*) i+j
    enddo
    do j = 1,20
         write(*,*) i-j
    enddo[/bash]
To take it a bit further, your original code using statement labels might look like this, where termination is unambigous:
[bash]     do 20, i = 1,10
        do 20, j = 1,20
          write(*,*) i+j
20  enddo
     do 30, j = 1,20
       write(*,*) i-j
30  enddo[/bash]
I think this was your point.
