29656 Discussions
Compile problems using tty in the source
Brian_Allison
If I compile my code (creating a dll) with Compaq's Compiler, there are no problems. If I try doing it with INTEL Fortran Compiler 10.1.021, I am getting complaints about the" write (tty,"(2a)") mssg,'failure.' "Statements.
Any Ideas? Does tty not work in a dll for the INTEL Fortan compiler?
Example? I don't recognize the issue based on your description.
Brian_Allison
Something about the tty. The Compaq compiler likes it just fine the dll. The INTEL Fortran compiler seems to be having problems with "tty". If I create an EXE it is just fine.
Sorry, I still don't understand. Please post example source, or perhaps attach a ZIP of the project. If nothing else, attach the buildlog.htm that shows the build errors.
Brian_Allison
Here is one of the many lines that I had to comment out in order for the DLL to work.
$if def,visa
case (9)
write (output,"('0',2a)") mssg,'VISA signal.'
! write (tty,"(2a)") mssg,'VISA signal.'
$endif
The write (output.... Line is just fine, but in order for the dll to run, I had to comment out all of the tty lines in 7 files.
DavidWhite
Valued Contributor II
Quoting - Brian Allison
$if def,visa
case (9)
$endif
Can you show thedefinition for TTY?
David
Brian_Allison
Here is where tty is defined.
! tty Online screen file.
!if -def,hp,1
integer, parameter :: tty=6
What are these lines "$if def and $end? They are not supported Fortran syntax,
Please show a small (if possible) but complete source - the actual source, not your paraphrase of it - that shows the problem, and also show the exact and complete set of error messages the compiler gives you. The problem is very likely to be different from what you think it is.
Brian_Allison
Not sure why there was dollar signs in front of the if and end. They were supposed to be !.
The problem is not in the compiling. When I am running the program that calls the DLL, it halts in the debugger at every single "tty" statement. The CVF dll works just fine. It is something with the way the IVF compiles the code.
Here is a sample of the first problem I am running into.
! Set program title.
! write (tty,"(a)") ptitle(1:24)
write (output,"('1',3x,a)") ptitle
If I leave the write statement for tty un-commented, then the program halts with this message in the debugger.
Unhandled exception at 0x00bf451a (relap5d.dll) in relap5cmd.exe: 0xC0000005: Access violation reading location 0x00000000.
It halts on the line with the tty in it.
Ok, more information is helpful. What is the program that calls this DLL? Does it open a console window? One change you may be running into is that in earlier versions, if you tried to do console output when there was no console, the error was ignored, but now you'll get "error 38". That is likely to change in a future update so that it is ignored again. But the access violation is not normal.
It is not "tty" that is the issue but the write to unit 6.
