29648 Discussions
Compiler Bug: derived type specifier in array constructor
Rodrigo_R_
Hi.
I am getting a syntax error when trying to construct an array with a type specifier, when the type is a derived type.
program test
  type :: tp
   integer :: a
  end type
  type(tp) :: u(0) = [tp ::]
  ! error #5082: Syntax error, found '::' when expecting one of: ] , (/ :
  type(tp) :: v(2) = [tp :: tp(0), tp(1)]
  type(tp) :: w(2) = [tp(0), tp(1)]
  ! no error
  integer :: x(2) = [integer :: 0, 1]
  ! no error
end
My compiler version is 18.0.2.185 Build 20180210 x64 on Windows.
I can compiler and run the sample code without problems in gfortran.
Steve_Lionel
Still fails in 19.0. I concur that the syntax should be accepted. Please report this through https://supporttickets.intel.com/?lang=en-US
