29653 Discussions
Compiler Versions vs Developer Studio
Raghu
Dev studio 97 with Fortran Compiler 5.0 (F90) - Is this still a valid environment to work?. I am getting link1104 errors with missing kernel32.lib? Running under 32 bit XP. Please help
Whose Fortran 5.0 are you using? If it is Digital Visual Fortran, then VS97 is the corresponding version. Of course, that is a 12-year old version... kernel32.lib should be in the VCLIB folder.
Raghu
From missing links I can see its from HP. I confirm kernel32.lib file in its location. Compiles OK but errors out while building. See message below...
Linking...
LINK : fatal error LNK1104: cannot open file "dfor.lib"
Error executing link.exe.
Thanks for your reply!
That is Digital Visual Fortran. Not really "from HP". Are you sure about the version? dfor.lib will be in, I think, Program FilesDevStudioDFLIB Are you building from a command line or from Developer Studio? Perhaps a reinstall of DVF will solve your problem.
I don't have that version installed so can't be of too much help trying to get it running for you. It is from 1997.
Raghu
Yes, you are right, I located that file. I also added the paths of these lib files under Tools-Options-Directories. Tried building again with the following error. I am sure you can help me on below ... !!! Thanks.
ER533A.OBJ : error LNK2001: unresolved external symbol _ASSIGN@12
ER533A.OBJ : error LNK2001: unresolved external symbol _CLOSE@4
Debug/ER533A.exe : fatal error LNK1120: 2 unresolved externals
It sounds as if you have "CALL ASSIGN" and "CALL CLOSE" in your program. These are old, non-standard routines that are not supported by DVF. CALL ASSIGN is usually replaced by an OPEN statement and CALL CLOSE can be replaced with CLOSE. Please consult any Fortran textbook post-1977, or the Digital Fortran Language Reference Manual, for information on these.
