loop for non-integer
Help
Can anyone let me know how to loop through non-integers values like from 0.001 to 9.999
Peter
Quoting - Help
First of all why do you want to loop a non integer ??
For example, if you want step size of 0.001b/t 1 and 10 ,you may write as follows
[cpp]real(8) i
do i= 1.d0,  10.d0  ,  0.001d0
print*, 'whatever you want'
end do
[/cpp]
Can you be more specific by giving an example what you want to do?
Non-integer DO loops are deleted from the standard. Our compiler still supports them, but they're a bad idea, especially as you may be surprised at how many times the loop runs.
Peter
Steve,
Are you referring to my code ?? If sothere are lot of situations in engineeringproblems that have to loop many times, for example trying to achieve convergence etc.
Ifyou are referring to theoriginal discussion, I did not understand why he/she wants to loop non integer numbers !
TimP
Quoting - Peter
[cpp]real(8) i
end do
[/cpp]
This was supported in f77 standard, but later deleted from the standard, as e.g.
integer i
do i=1,9999
write(*,*) i*0.001
enddo
has advantages such as an exactly known loop count.
jimdempseyatthecove
Quoting - tim18
integer i
do i=1,9999
write(*,*) i*0.001
enddo
Tim18,
You would want to use "i*0.001D0" or "i*0.001_8" as the original loop code showed use of D variables.
Jim Dempsey
Help
Quoting - Peter
Steve,
Hi Peter,
Thanks for the do loop. It worked for F90.
I wanted to do a small test with non-integer. I have a code where I had to do negative exponential calculations over large values and was never coming out of the loop. So, I had to find the value where it was stuck. This was for the very same purpose (convergence) you have explained.
Thanks again..
Peter
Quoting - Help
Hi Peter,
Thanks again..
Yeah I kinda figured that you'l be looking for some convergence ! Good luck running your code !
Help
Quoting - Peter
Thanks Peter...and thanks to everyone who replied to this post
