Compiler Won't Build Solution
kgyovai
I currently use Intel Visual Fortran Composer XE 2011 for windows to compile. Today I started having 2 problems:
1) WhenI open an existingproject with a free form (f90) sourcefile, the composer opens the file as if the file wasinfixed format (for). The language setting under project properties has been set to "identify by file type". When I look under properties of the source file I am only given options for "general".
2) My projects are not building. If I change a project, then try to build, the compiler says that the project is up to date even though I just changed it.
I have reinstalled the compiler but that hasn't helped. Any advice would be greatly appreciated.
Kane
Tools > Options > Intel Visual Fortran > General. Click the "Reset" button under both Free Form and Fixed Form source file types. Click OK.
