29641 Discussions
Compiler bug? Incorrect error message RE: (de)allocation of local polymorphic variable in element/pure procedure
Izaak_Beekman
New Contributor II
I'm wondering if I've stumbled upon another compiler bug. I'm using ifort (IFORT) 13.0.2 20130314 on 64 bit Intel Mac OS X Mavericks.
Is this an error with ifort's interpretation of the standard, or with my interpretation? I think that allocation and deallocation of polymorphic local variables should be allowed inside pure and elemental subroutines.
With ifort 13.x when I check my code if it's valid I get the following error:
[bash]$ ifort -warn -stand f08 -syntax-only -fpp statN.F90
statN.F90(96): error #7146: This object must not be used as an allocate-object in an allocate-stmt or deallocate-stmt in a PURE procedure or an internal procedure contained in a PURE procedure.   [LOCAL_RES]
             deallocate(local_res)
statN.F90(97): error #7146: This object must not be used as an allocate-object in an allocate-stmt or deallocate-stmt in a PURE procedure or an internal procedure contained in a PURE procedure.   [LOCAL_RES]
             allocate(local_res,source=rhs)
----------------------^ [/bash]
However, gfortran makes no such complaints:
[bash]$ gfortran -fsyntax-only -Wall -pedantic statN.F90
$ [/bash]
local_res is a local, allocatable, polymorphic variable. At the end of the function it's allocation is moved to the result variable (which is also allocatable polymorphic but declared as the parent (abstract) type.
The lines of the procedure which cause the problem are listed below:
[fortran]
  elemental function Reduce(lhs,rhs) result(res)
    !Associated covar objects must be reduced by client code
    !Calculate statistical moments of the union of two sets
    class(statN_t)  ,intent(in)  :: lhs
    class(spocs_t)  ,intent(in)  :: rhs
    class(spocs_t)  ,allocatable :: res
    class(statN_t)  ,allocatable :: local_res
    allocate(local_res,source=lhs) !Copy object and components
    select type(rhs)
    class is (statN_t)
       if ((BIGGEST_INT - lhs%n) < rhs%n) then !about to overflow
          if (rhs%n > lhs%n) then !return whichever set has the most samples
             deallocate(local_res)          !ifort doesn't like these two
             allocate(local_res,source=rhs) !lines. :-(
          end if
          ! Do some error handling. Make an error state variable
          call move_alloc(from=local_res,to=res)
          return
       end if [/fortran]
Again, I'm quite pressed for time, but will try to come up with a suitable reproducer as soon as I can.
Izaak_Beekman
New Contributor II
After further review, it looks like I am mistaken, and my code is violating the standard. I was refered to F08/0033: PURE polymorphic finalization here: ftp://ftp.nag.co.uk/sc22wg5/N1851-N1900/N1875.txt
It seems that deallocate() statements called with polymorphic arguments are not allowed within pure procedurs because it is not known at compile time whether or not such objects have impure finalization procedures. Additionally, the problem with the sourced allocation is the pointer components of the source, which could dereference to global variables etc.
Sorry for the false alarm.
Thanks for the update.
