29657 Discussions
Compiler bug: Procedure pointer association status gets lost
Balint_Aradi
The Intel oneAPI Fortran compiler (ifx (IFX) 2024.2.0 20240602 on x86_64/Linux) produces erroneous executable, where an associated procedure pointer loses its association under certain conditions. Below the MWE example extracted from the Fortuno unit testing framework, demonstrating the issue:
module test_generator
  implicit none
  type :: serial_case_base
    character(:), allocatable :: name
  end type
  type, extends(serial_case_base) :: serial_case
    procedure(argless_proc), pointer, nopass :: proc => null()
  end type serial_case
  abstract interface
    subroutine argless_proc()
    end subroutine argless_proc
  end interface
  type :: test_item
    class(serial_case_base), allocatable :: item
  end type
contains
  function get_tests() result(testitems)
    type(test_item), allocatable :: testitems(:)
    testitems = [test_item(serial_case(name="proc_call", proc=test_proc_call))]
    ! Test, wether procedure can be called
    select type (p => testitems(1)%item)
    type is (serial_case)
      print *, "1:START calling proc()"
      call p%proc()
      print *, "1:END calling proc()"
    end select
  end function get_tests
  subroutine test_proc_call()
    print *, "hello from test_proc_call"
  end subroutine test_proc_call
end module test_generator
program testapp
  use test_generator, only : get_tests, test_item, serial_case
  implicit none
  testitems = [get_tests()]
    print *, "2:START calling proc()"
    call p%proc()
    print *, "2:END calling proc()"
  end select
end program testapp
Compiling the code with ifx (without any options) and executing it results in a segfault with following output:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
libc.so.6          00007F1766F56710  Unknown               Unknown  Unknown
a.out              0000000000404A98  Unknown               Unknown  Unknown
 The code is standard conforming as far as I can see, and other compilers (e.g. NAG, GNU) seem to have no problems to generate a non-segfaulting executable.
A few additional observations:
  • The first call test at line 33 works out as supposed. It is the test at line 59, which causes the segfault.
  • Leaving away the array constructor at line 53 (using "testitems = get_tests()" instead of "testitems = [get_tests()]") results in a working executable.
  • Moving the definition of the field "name" into the extending type (serial_case) results in a correctly working executable.
  • Removing the definition of the field "name" (and adapting the structure constructor in line 27 accordingly) also leads to a working executable.
Ron_Green
I see this error also.  It seems to be a change between the 2024.0.0 and the 2024.1.0 compiler that broke.
I will get a bug report started.
the 2023.2.0 or 2024.0.0 compiler works for this example.
Balint_Aradi
Yes, indeed, with 2024.0 we had no problems. Thanks for taking care about it (it is unfortunately a showstopper for Fortuno).
Balint_Aradi
Please note, that 2024.2 (ifx (IFX) 2024.2.1 20240711) still contains this bug. Any chance, that it will be soon fixed?
Devorah_H_Intel
@Balint_Aradi  I will check the status and update you soon.
Devorah_H_Intel
This issue is not fixed yet. However we are planning on fixing it in future compiler releases.
Ron_Green
the fix for this did not make the upcoming 2025.0 release.  However, it is fixed in 2025.1 which is our active branch.  That 2025.1 release should release in roughly late March or April 2025.
