29657 Discussions
Compiler bug: Repeated polymorphic assignment raises run-time error
Balint_Aradi
Dear all,
the current Intel compiler (ifort (IFORT) 2021.4.0 20210910 on x86_64.Linux) produces a badly behaving binary for the code below. The code is, as far as I can judge, standard conforming, but when executing the produced binary, I get a run-time error and the code stops.
module test
  implicit none
  type :: base_t
  end type base_t
  type, extends(base_t) :: extended_t
    integer :: ii
  end type extended_t
contains
  subroutine pop(item)
    class(base_t), allocatable, intent(inout) :: item
    class(base_t), allocatable :: buffer
    call move_alloc(item, buffer)
  end subroutine pop
end module test
program testprog
  use test
  implicit none
  class(base_t), allocatable :: base
  base = extended_t(41)
  call pop(base)
  base = extended_t(42)
  print *, "DONE"
end program testprog
The resulting binary stops with the run-time error
forrtl: severe (122): invalid attempt to assign into a pointer that is not associated
Image              PC                Routine            Line        Source
a.out              0000000000407A56  Unknown               Unknown  Unknown
a.out              0000000000403FA2  Unknown               Unknown  Unknown
a.out              0000000000403862  Unknown               Unknown  Unknown
libc-2.31.so       00007F5C8FC1E0B3  __libc_start_main     Unknown  Unknown
a.out              000000000040376E  Unknown               Unknown  Unknown
Interestingly, when I comment out the pop() call, the program runs without errors, so I guess, something bad happens to the descriptor of base, when it is passed forth and back in the call.
Balint_Aradi
Actually, it seems, that it is the move_alloc(), which leaves the descriptor in a bad state. The following simplified example generates the same behavior:
program testprog
  implicit none
  type :: base_t
  end type base_t
    integer :: ii
  end type extended_t
  class(base_t), allocatable :: base, buffer
  call move_alloc(base, buffer)
  print *, "DONE"
Devorah_H_Intel
Thank you for the report. This issue is now escalated to compiler engineering.
Devorah_H_Intel
This issue has been fixed in the current oneAPI 2023.
