29653 Discussions
Internal error using parameter while having constructor with the same name as derived type
gzengm
Minimal reproducible code snippet:
module vector3d_module
   implicit none
   type :: vector3d_type
      real :: x = 0.0
      real :: y = 0.0
      real :: z = 0.0
   end type vector3d_type
   type(vector3d_type), parameter :: vector3d_zero = vector3d_type(0.0, 0.0, 0.0)
   interface vector3d_type
      module procedure vector3d_constructor
   end interface
contains
   function vector3d_constructor() result(res)
      implicit none
      type(vector3d_type) :: res
      res = vector3d_zero
   end function vector3d_constructor
end module vector3d_module
program main
   use vector3d_module
   implicit none
   print *, vector3d_zero
end program main
Compiler version: ifort 2021.8.0 Build 20221119_000000
Barbara_P_Intel
I just tested this reproducer with the compiler that will be released in shortly. NO ICE!! Both ifort and ifx compile without errors.
I do get ICE with the current compiler, 2021.8.0, as reported.
andrew_4619
for the record The ICE is on the main program changing the interface name to "vector3d_type1" compiles OK.
Source1.f90
C:\Users\...\Console3\Source1.f90: internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
C:\Users\...\Console3\Source1.f90: catastrophic error: Internal Compiler Error: Ref module: ffe_param.c
Clearly an ICE is bug no argument.
As an aside:
1] why have parameter vector3d_zero at all when you have default initialisation to zero in the type definition?
2] why try to redefine the defualt constructor why not use a modified name  for an alternative constructor?
gzengm
Thank you for your response, andrew_4619!
The initial code snippet I provided was just a minimal example to demonstrate the issue. However, here's a more practical version of the code that still encounters the same error:
   implicit none
      real :: x = 0.0
      real :: y = 0.0
      real :: z = 0.0
   type :: vector2d_type
      real :: x = 0.0
      real :: y = 0.0
   end type vector2d_type
   type(vector3d_type), parameter :: vector3d_unitx = vector3d_type(1.0, 0.0, 0.0)
      module procedure vector3d_from_vector2d
   end interface
contains
   function vector3d_from_vector2d(vector2d) result(res)
      implicit none
      type(vector2d_type), intent(in) :: vector2d
      res%x = vector2d%x
      res%y = vector2d%y
      res%z = 0.0
   end function vector3d_from_vector2d
program main
   use vector3d_module
   implicit none
   print *, vector3d_unitx
end program main
gzengm
In response to your question about using vector_zero while having default initialization to zero in the type definition, I believe that employing a predefined parameter, such as vector_zero, is a good practice. This approach ensures that we explicitly reference a clearly-defined constant, rather than relying on default initialization values. This can lead to more maintainable and understandable code, especially when working with larger or more complex projects.
Source1.f90
As an aside:
andrew_4619
Interestingly this compiles OK if you use 'last years' compiler rather than the latest so the ICE is a regression.
Barbara_P_Intel
