I have now moved to oneAPI+ifort. I guess MPI-applications will still be run from the command line, won't they.
As the "old workhorse" ifort will be succeed by the "mustang" ifx, it is probably good to prepare for the transition.
Best regards
Anders S
mpiifort -fc=ifx
that tells the MPI wapper to use IFX instead of IFORT
This guide will show how to go from ifort+QuickWin+MPI to ifx+QuickWin+MPI. This can be useful if you want to use the same code for both Windows and Linux.
First, download and install the Intel Fortran Compiler. Then, set the environment variable "IFORT_COMPILER" to the path of the Intel Fortran Compiler. Next, download and install the QuickWin library. Finally, set the environment variable "QUICKWIN_LIBRARY" to the path of the QuickWin library.
Once all of the necessary software is installed, you can compile your code with the Intel Fortran Compiler by using the following command:
ifx -c mycode.f90 -o mycode.obj
You can then link your code with the
