Compiler bug with associate construct
sfranzen
I was playing around with a way to record log messages in an internal "file" (character variable) when I came upon a strange compiler notice. The following module does not compile, producing the error
error #7146: This object must not be used as an allocate-object in an allocate-stmt or deallocate-stmt in a PURE procedure or an internal procedure contained in a PURE procedure.   [TEMP]
      allocate(temp(2*size(this%buffer)), mold = this%buffer)
Simply removing the associate construct gets rid of the error. Allocation and internal file I/O should both be fine in PURE procedures, right?
module logmod
  implicit none
  private
  type, public :: logger
    private
    character(128), allocatable :: buffer(:)
    integer :: idx = 1
  contains
    procedure, public, pass(this) :: info
  end type logger
contains
  pure subroutine info(this, msg)
    class(logger), intent(inout) :: this
    character(*), intent(in)  :: msg
    ! Temporary buffer
    character(:), allocatable :: temp(:)
    ! This unused association causes error #7146
    associate(i => this%idx)
      ! Check buffer status
      if (.not. allocated(this%buffer)) then
        ! Allocate and fill buffer of initial size 100
        allocate(this%buffer(100))
        this%buffer = ''
      elseif (this%idx == size(this%buffer)) then
        ! Increase buffer size
        temp(1:size(this%buffer)) = this%buffer
        call move_alloc(temp, this%buffer)
      endif
      write(this%buffer(this%idx), '(a)') msg
      this%idx = this%idx + 1
    end associate
  end subroutine
end module
pbkenned1
Looks like an ifort defect.  I'll report this to the developers.
patrick
pbkenned1
patrick
sfranzen
patrick
Thanks!
pbkenned1
This has been reported to the developers.  I'll keep this thread update with any news.  Tracking #DPD200254361
patrick
pbkenned1
Resolved in Composer XE 2013 SP1 Update 3:
[U507066]$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.3.174 Build 20140422
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
[U507066]$ ifort U507066.f90 -c
[U507066]$
Patrick
